My Legacy One Jem project - Jemsite
post #1 of 19 (permalink) Old 09-20-2008, 02:44 PM Thread Starter
Not sure if this is where the threads belongs, but I saw some other projects here so here I am. I've hung around a while here but not joined until recently. I thought I would share my project with everyone as I don't really see any posted here. I've made several guitars over the years, but this is my first Jem. I've owned a few of them, just never made one like this. So, hope this will help anyone thinking of doing a project of their own.
Body: from Legacy One, thanks Chris! It is a two piece alder body.
Neck: from Legacy One, should arrive in a week or so.
Bridge: Cosmo Lo Pro Edge, from Ibanez Rules, thanks Rich!
Pickguard set pearl also from Ibanez Rules
other parts ****!
I"ve always liked the 7VWH, but absolutely do not like the gold. To each his own. It would cost me more to buy one and replace all the hardware and pickups, so I'm going the DIY route.
Here is the body.
indeedido is offline
post #2 of 19 (permalink) Old 09-20-2008, 02:45 PM Thread Starter
Re: My Legacy One Jem project
Had a few burrs here and there, but overall a great body. All the Ibanez parts so far have fit perfectly.
Just a little sanding and it was ready for the sand sealer
post #3 of 19 (permalink) Old 09-20-2008, 02:49 PM Thread Starter
Deft sand sealer is the best, no doubt. I use a $5 brush, don't use the $.75 cheap brush or you'll be sanding the bristle brushes out from now til doomsday. I'm going to put on about 10 coats. Light coats. I want to be sure I have good coverage as most of it is going to be sanded off.
Here we are about 4 coats into it. The handle and lion's claw route are a pain in the ass. I'll be glad when this stage is done. I don't mind sanding, but I hate the sealer part. Very strong smelling stuff.
I plan on getting another 5 or 6 coats on today and tomorrow. I wait about an hour in between coats so it can dry before adding the next. Updates to follow
post #4 of 19 (permalink) Old 09-20-2008, 03:34 PM
Brosa's Avatar
Cool mate! It looks already good. Keep us updated.
Can't wait for the finished guitar to see.
Brosa is offline
post #5 of 19 (permalink) Old 09-20-2008, 09:27 PM
nice job. Take pix of the products your using. Im doing mine a bit darker
carbons2k is offline
post #6 of 19 (permalink) Old 09-22-2008, 01:57 AM
Is that a crack carbons2k?
Ibateur is offline
post #7 of 19 (permalink) Old 10-03-2008, 07:52 PM Thread Starter
Ok, I'm back on track. I have been busy, but am back on it. Here are a couple of products I like to use. Deft Sand Sealer is by far the best.
REMEMBER: If you are going to use lacquer paint, use a lacquer sealer. Any thing under lacquer that is oil or water based will be eaten by the lacquer. I'm using lacquer paint, so I'm using lacquer sand sealer.
post #8 of 19 (permalink) Old 10-03-2008, 07:52 PM Thread Starter
post #9 of 19 (permalink) Old 10-03-2008, 07:53 PM Thread Starter
post #10 of 19 (permalink) Old 10-03-2008, 07:56 PM Thread Starter
Now that I have my 10 coats of sand sealer, it is time to begin sanding. I'm using 320 grit wet/dry paper, but am using it dry. You're going to want to use a sanding block or else you won't get your surface level. You'll get finger marks in it and waves. You can use a 9 volt battery wrapped in sand paper or a small wooden block, or do like I did and go to your local automotive paint shop and get a sanding block. You are also going to want to do this outside because as you sand, the sealer will turn to dust. Lots of white dust. You can see here the difference of where I have and havn't sanded.
post #11 of 19 (permalink) Old 10-03-2008, 07:57 PM Thread Starter
post #12 of 19 (permalink) Old 10-03-2008, 07:58 PM Thread Starter
In the last picture above, you can see some high spots. That is what you are trying to get out. Any high spots will show once you've painted. You want them gone for a smooth factory finish.
post #13 of 19 (permalink) Old 10-03-2008, 08:02 PM Thread Starter
You'll know when you are done because all of the shiney high spots will be gone. You'll have a nice, flat, smooth surface. When you are done, wipe all the dust off with a tack cloth and blow out the cavities with a can of compressed air. Then wipe the whole thing down with either lacquer thinner or Naptha. I use Naptha. Either will work.
Once you get it wiped down really good, you are ready to prime! I like to use the white primer from guitar reranch dot com. It is awesome stuff. Goes on matte for a great surface for the paint to adhere to. I bought a can gun from the hardware store to make it easier to shoot with. Dig......
post #14 of 19 (permalink) Old 10-03-2008, 08:06 PM Thread Starter
Now for the finished primer shots, front and back
Now it is starting to look like a Jem!!!
After the primer dries for a day or so, I block sand it again to smooth out the rough surface. 320 grit again. You don't sand much, just enough to smooth it out. this primer is sandable, and works nicely. Again let the paper do the work with the sanding block. You don't want to sand through it. When you feel it is smooth, wipe down again with tack cloth and Naptha and get ready to shoot color.
I just shot the white color tonight. I'm going to hit it with another coat tonight and one again in themorning. I'd show you another pic, but it looks just like the primer shot as I'm shooting it white. I'm using automotive paint, and in fact I'm painting it bright white. I took the paint code from my wifes Toyota Highlander and am painting the same color. I'll post pics tomorrow
post #15 of 19 (permalink) Old 10-03-2008, 08:19 PM
Lordiesel's Avatar
Looks good man. I'm getting inspired to do one of my own.
Lordiesel is offline
Ever wondered how much your project will cost ?? Post project costs here ! Jaden Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 12 08-29-2006 07:48 PM
Should I sell my Legacy combo to buy a Legacy head and cab.? Given to Fly Gear, Equipment, Recording & Off Topic 9 07-19-2004 06:43 PM
recording project isn't looking good - recording project isn shredmaster Ibanez JEM, UV, JS & Other Signature Models 8 11-12-2001 10:17 AM
Project Axes - project guitars Bradly Smith All Other Guitars (including Prestige) 4 10-09-2001 06:50 PM
Project Guitar Ideas - Opinions wanted on project jem7vwh Tech: Setup, Repairs and Mods 11 12-19-2000 11:27 PM
HTML code is On
