Is my neck too straight and truss rod messed up? - Jemsite
post #1 of 5 (permalink) Old 05-03-2011, 09:10 AM Thread Starter
Good morning Jemsite!
I decided to post this here because the *problem* I'm about to explain is on my JS1000BP. And everything explained is while the guitar is unplugged
For about 8 months- 1 year, I noticed some really high pitch fret noise when I hammer on. While I know its normal to some extent, there are really specific places when I can hear it quite loud and have a feeling it kills the note.
Example:
On the first string when I do a hammer-on from B to D (7th fret to 10th...and many other areas for that matter) I can really hear the high pitch *tick* really loud and for some reasons it does the same thing on the 2nd string for the same notes (12th fret to 15th).
I know its not the frets because they're only one year old and I've had a recent file job done on them and they seem perfect. What I was thinking is that my neck was too straight so when I was doing some hammer-ons the string would hit a lower adjacent fret so it would kill the note a little bit thus reducing the sustain a lot.
Truss rod messed up?
While trying to give my neck some slight relief to fix the problem stated above, I noticed that my truss rod is loose and actually peaks out more more as I loosen it but it does nothing to the *shape* of the neck. I've had the guitar for almost 10 years and it wasn't like that before. Ohhh I can tighten it alright and have the neck concave but I can only loosen it a little with some effect to the neck before it becomes loose and peaks out more and more. I came to the conclusion that indeed something is wrong so here is 3 options that I consider:
1st. I need re-tighten the truss rod a little bit, lay down the guitar flat and put some weight on the neck so it gets some relief and that would result with having room for neck adjustment while the truss rod isn't loose so I can tighen or loosen the truss rod to my liking and have a direct change to the neck relief. (Would I need to unscrew the neck from the body or do I leave it screwed on to the guitar?)
2nd- Basically the same thing as the 1st one but give it to a luthier and ask him to heaten up my neck.
3rd- I'm a paranoia case and everything is normal?
I know some of you might say *Well, its unplugged so why should it bother you when you play with the guitar plugged since the fret sound will be masked by the volume and/or distortion?* While this is true, I know deep down inside that it's not supposed to do that and it bugs me. I want my guitar to be in perfect condition
Please, do give me some insights!!
EDIT: Neck has minimal relief. Its the fret noise that bugs me the most.
RemyL is offline
post #2 of 5 (permalink) Old 05-03-2011, 10:52 AM
Reviews: 11
Re: Is my neck too straight and truss rod messed up?
Um if its fret noise and fret problems, its a good indicator your fret job isn't as good as you think.....
And a neck can't be" too straight".
linuxpenguin is offline
post #3 of 5 (permalink) Old 05-03-2011, 11:01 AM Thread Starter
You have a good point!
Sorry for 'neck too straight' lol...didn't express myself correctly.
RemyL is offline
post #4 of 5 (permalink) Old 05-03-2011, 03:06 PM
Reviews: 11
easy check, go get yourself a TRUE straightedge and see if your frets are all level.
post #5 of 5 (permalink) Old 05-03-2011, 04:17 PM Thread Starter
thanks!
RemyL is offline
frets , neck , truss rod
FS RG540PII 24fret skolnick neck. straight low action dgabriel713 Classified Ads: Guitars and Gear 3 12-22-2010 11:08 PM
Rg neck thru truss adjustment??? help! Nick 6 All Other Guitars (including Prestige) 1 07-23-2008 02:17 PM
What kind of TRUSS ROD on JEM 77 FP NECK ? Metallion Ibanez JEM, UV, JS & Other Signature Models 0 03-30-2007 07:38 AM
New 5 piece Jem neck bow/truss rod adjustment chris101 Ibanez JEM, UV, JS & Other Signature Models 1 01-17-2007 11:26 AM
Jem10 Neck 2: Truss Rod burt777 Tech: Setup, Repairs and Mods 22 01-31-2004 01:50 PM
HTML code is On
