Neck/Bridge Volume differences on JS - Jemsite
post #1 of 4 (permalink) Old 01-02-2008, 01:25 AM Thread Starter
eg
Have you guys noticed any volume differences between the neck - pafpro and bridge - fred pickup on your JSes?
I've read that for equally powered pickup, the neck position would sound somewhat louder because the string amplitudes are greater there. Then given the fact that the pafpro and the fred are quite close in terms of output, then would this cause the paf pro to sound kind of louder that the fred.
I have the same pickup config on my RG and I notice there the neck pickup is slightly louder.
If this is true, how do you guys compensate?
Thanks
eg is offline
post #2 of 4 (permalink) Old 01-02-2008, 02:01 AM
Re: Neck/Bridge Volume differences on JS
the Fred is a little higher output than the Paf Pro which is perfect
if your neck pickup seems too loud try lowering it with the adjustment screws or try raising your bridge pickup.
RSVampire is offline
post #3 of 4 (permalink) Old 01-02-2008, 07:06 AM
i noticed itm but it was because my paf pro was higher than the fred..so i lowered it and its now below in its cavity whereas the fred just sits on the top
millzy is offline
post #4 of 4 (permalink) Old 01-02-2008, 10:00 PM Thread Starter
eg
Alright, I guess I'll have to adjust the heights to compensate
eg is offline
bridge pickup , neck pickup , neck position , paf pro
Effects loop volume drop in Prosonic sanchez Gear, Equipment, Recording & Off Topic 3 05-31-2005 08:06 PM
HELP! Volume pot problem on my js1000btb. Vaislittlefinger Ibanez JEM, UV, JS & Other Signature Models 5 03-03-2005 08:26 PM
Volume pedal for Solo boost Dan D Mahnn Gear, Equipment, Recording & Off Topic 7 06-21-2003 01:03 PM
Old JS 100BK HDS Ibanez JEM, UV, JS & Other Signature Models 2 12-31-2002 12:21 PM
JS PU change sugguestions? - im thinking about changing out SuperUnderwhereMan Ibanez JEM, UV, JS & Other Signature Models 23 01-30-2002 08:15 PM
HTML code is On
