Neck finishes on Jems - Jemsite
post #1 of 10 (permalink) Old 05-30-2002, 03:09 PM Thread Starter
Are all Jem necks finished, and if they are, are they easy to strip?
lhrocker is offline
post #2 of 10 (permalink) Old 05-30-2002, 05:21 PM
kennydoe's Avatar
Most are lightly fnished with oil - none with laquer like a Strat.
They're easy enough to get the finish off with a little fine sandpaper. Takes about 10 minutes and imporves the neck feel 100% in my book. Hers instructions from the Tech section: http://www.jemsite.com/tech/t_2mods.htm#necksand
have fun
~Kenny
kennydoe is offline
post #3 of 10 (permalink) Old 05-31-2002, 09:52 AM
I agree, takes like 10 minutes and vastly improves the feel of the guitar. I sanded my 2027 a while back...100% improvement and I thought it was great before!! Just follow the tutorial.
Gresh is offline
post #4 of 10 (permalink) Old 05-31-2002, 10:15 AM
The BSB neck is unfinished, in a way, I mean it is burnt and stained, but it is effectively unfinished. The UV necks (the older ones) are unfinished as well. I prefer the feel of no finish as well.
7 Dying Trees is offline
post #5 of 10 (permalink) Old 05-31-2002, 10:28 AM
of course I have to throw in that I like high gloss finish!!!
Has nothing todo with the topic.. I just like being the odd ball! I also like the tung oil finished necks of EBMM guitars... they are pretty nice too. I don't like the slack crap neck finish on Strats.. course I have a yjm strat, which has, you guessed it, 7 or 11(I forget) layers of high gloss!!! and yes I love the unfinished feel.. i just don't like the neck turning dark and all the up keep and potential neck damage due to no protection.
BrianH is offline
post #6 of 10 (permalink) Old 05-31-2002, 01:47 PM
Will this trick work on my RG570?
johank is offline
post #7 of 10 (permalink) Old 05-31-2002, 02:37 PM
kennydoe's Avatar
it's not a trick...and it will work on any piece of wood, not just a guitar neck. Sandpaper removes finish.
putting some sort of protective oil on the neck is highly recommended. The wood will soak it up and your neck will still feel like natural wood, but wood needs to be kept somewhat moist. I sanded my 550 neck without oiling it and it started to come apart at the headstock seam.
~Kenny
kennydoe is offline
post #8 of 10 (permalink) Old 05-31-2002, 03:25 PM
site founder 0% owner
jemsite's Avatar
good advice here. on a 100% new raw/unfinished custom neck, oil should be used to help keep it stable and not bow, etc. as the climate changes. I'll be oiling my GC Custom neck ASAP... haven't gotten around to it and in the summertime/humididy the neck backbow is effected. I've found when sanding down a JEM, RG, etc. neck you don't quite sand so much that you should be effecting the stability, glue joints, etc. The wood has been sealed for years, in case of an older axe. Of course, this depends on many things, including outside factors such as the climate, weather, etc. Good luck... glen
jemsite is offline
post #9 of 10 (permalink) Old 06-03-2002, 04:17 PM Thread Starter
I took the finish off my 777dy following the Jemsite instructions and it came out great, so I decided to do the rest of my Jems sometime this week.
On thing I noticed, for me anyway, is that the neck actually feels best after the 600 grit and not having the 0000 steel wool afterwards. I did this on an RG570, after I did the Jem, and the 600 sanding is the best feel for me.
Thanx to everyone for the help and info.
Peter
lhrocker is offline
post #10 of 10 (permalink) Old 06-06-2002, 01:27 PM
I'm thinking about sanding every maple neck I own. I love the feel of the unfinished neck on my FP.
Rockstar is offline
jem neck , maple neck , neck finish , steel wool , tung oil , yjm strat
Speed: frets and neck finishes Zeppel Ibanez JEM, UV, JS & Other Signature Models 2 01-24-2004 10:17 PM
Lets talk neck finishes!!!!! gemini8026 All Other Guitars (including Prestige) 5 10-05-2003 06:20 PM
Wolfgang, EB/MM neck finishes... what exactly is it? oooo Tech: Setup, Repairs and Mods 6 02-12-2003 09:51 PM
Neck angles on Jems and RG's lhrocker Tech: Setup, Repairs and Mods 1 05-16-2002 01:35 PM
Why not neck through? - Jems/Universes kirk Ibanez JEM, UV, JS & Other Signature Models 16 03-21-2001 06:11 AM
HTML code is On
