Neck joint crack on older Jems - What is this "neck joint cr - Jemsite
post #1 of 2 (permalink) Old 03-06-2001, 10:59 PM Thread Starter
I've been hearing things on and off over time, mostly on eBay auctions for older JEM guitars (with original bolt on neck joint, not AANJ). I havn't heard it a large amount of times, but enough to get me wondering, becuase on my JEM7PBK, I notice somthing and I think it might be what the others were referring to. I posted a pic in the File Upload sectiono of this board, the pic is called "jemcrack1.jpg". The red line I drew in is running parallel to the crack. The crack is about 1.25" long, and is straight. It appears to be only in the lacker coat, but I'm not sure. I bought this guitar used, and I'm guessing that crack was there for a while. The guitar plays fine, that crack dose'nt make a bit of difference. I'm just worried that it will get bigger, and evolve to a larger problem. Is this the "neck joint crack" that I've heard about in the past? Thanks. I plan on taking it to my local guitar store too : ) Thanks again!
Matt
Matt55655 is offline
post #2 of 2 (permalink) Old 03-06-2001, 11:33 PM
site founder 0% owner
jemsite's Avatar
See discussion in the thread in the Forum FAQ Archive Area
Neck joints on early jems
jemsite is offline
Closed Thread
neck joint , neck joints
Universe neck joint crack milkywayslipnslide Ibanez JEM, UV, JS & Other Signature Models 6 08-14-2010 01:13 AM
Hairline crack on neck joint acdc51502112 All Other Guitars (including Prestige) 2 04-12-2008 04:41 PM
Seriousness of neck joint crack? Marvel627 All Other Guitars (including Prestige) 19 12-11-2006 07:25 PM
Stress crack on neck joint, or just a finish crack? m0p Tech: Setup, Repairs and Mods 6 11-09-2005 05:59 PM
AANJ vs. Older Jem Neck Joint lhrocker Ibanez JEM, UV, JS & Other Signature Models 13 05-29-2002 09:04 AM
HTML code is On
