Neck joint stress cracks? - Jemsite
post #1 of 12 (permalink) Old 04-21-2008, 03:56 PM Thread Starter
Wondering how common neck joint stress cracks are in JS's? Because mine's developed one and I'm wondering how much I should be worried. The neck is not bolted on too tight, but I haven't had it off to check to see if it's just the paint or not.
heffergm is offline
post #2 of 12 (permalink) Old 04-21-2008, 06:43 PM
Re: Neck joint stress cracks?
-- It's in the wood, not just the finish
-- It's fairly common ... at least for certain years
-- Nothing to worry about
ryanb is offline
post #3 of 12 (permalink) Old 04-22-2008, 12:35 AM
Rich will step in the room soon and take care of this question....
Darin is offline
post #4 of 12 (permalink) Old 04-22-2008, 12:40 AM
It was pretty much covered
Basswood, and plate joint, much more common, but can happen to any of them. I have a JS1 right now where it's wrapped 4" around and down the back, and still tight and stable. They are what they are, why worry?
Rich is offline
post #5 of 12 (permalink) Old 04-22-2008, 03:39 AM
Passion_and_Warfare's Avatar
While were here, Rich was it common for 2007 JS1200's to have small NJFC's?
Passion_and_Warfare is offline
post #6 of 12 (permalink) Old 04-22-2008, 03:55 AM
It is not common for a JS, but I reject about 1 in 6/7/8 something that show up at the dealer with a short one. MO, it's the TJC case, even after the redesign.
Rich is offline
post #7 of 12 (permalink) Old 04-22-2008, 03:59 AM
That's what case mine was sent in, and it turned up with a small NJFC, about 1.5mm. Dealer said there was quite a few 07 models with simillar problems.
post #8 of 12 (permalink) Old 04-22-2008, 12:24 PM
Passion_and_Warfare, can you post a pic or 2 of it please?
modal is offline
post #9 of 12 (permalink) Old 04-24-2008, 03:15 AM
What do you think could be done differently to resolve the problem from the factory/manufacturing? Is it body design, or the wood going through seasonal type changes, or.....
Is this most common with JS's?
Darin is offline
post #10 of 12 (permalink) Old 05-19-2008, 09:49 PM
Yes to all except the first one.
Mine has cracks on both sides, but its definitely not in the wood. The cracks are too small and the finish is harder than the wood, making is more brittle and easier to break. It would be hard for me to believe that this also crack the wood, seeing as i have never dropped it, shipped it, or done anything to cause it to crack.
But of course, it depends on how brutal you are with it.
dogismycopilot is offline
post #11 of 12 (permalink) Old 05-19-2008, 09:53 PM
Yes to all, including the first. Not every single one may be, but it's far more realistic to assume they are than try to justify they aren't.
Rich is offline
post #12 of 12 (permalink) Old 05-24-2008, 03:58 PM
Gotta 11-07 JS1200. So far still good even after serious gigging and full-time use.
P. Aaron is offline
neck joint
Scarf Neck Joint Headstock? CaptainD00M All Other Guitars (including Prestige) 1 01-31-2008 01:03 AM
Advice needed on jem neck joint jsdisciple Ibanez JEM, UV, JS & Other Signature Models 8 12-31-2006 01:12 PM
WTB: RG550 with Maple neck and Orignal neck joint AirGuitar Classified Ads: Guitars and Gear 11 06-15-2006 09:59 PM
shaping and neck joint on j custom Bezial All Other Guitars (including Prestige) 21 03-15-2006 04:09 AM
Changing a JS neck joint to AANJ? Scott 74 Tech: Setup, Repairs and Mods 10 08-21-2002 11:48 PM
HTML code is On
