Neck pocket crack. - Jemsite
post #1 of 28 (permalink) Old 01-10-2007, 05:06 PM Thread Starter
Neck pocket crack.
Should i have it fixed or leave it.Whats the worst case scenario.
Zoot is offline
post #2 of 28 (permalink) Old 01-10-2007, 05:07 PM
Sabre's Avatar
Re: Neck pocket crack.
That's pretty deep, maybe you should get it checked out.
Sabre is offline
post #3 of 28 (permalink) Old 01-10-2007, 05:37 PM
I have the same thing on my 777sk, and it's even deeper than that! It's so common though, I don't think there's anything to worry about it, but I could be wrong. Just by doing a little research on jemsite, it's seems that it's the norm on these older jems, even one guy mentioned that vai has a neck pocket crack on one of his jems, and if he can live with it, you certainly can!
Ziggy_Franklin is offline
post #4 of 28 (permalink) Old 01-10-2007, 05:43 PM
Dee
This is normal and most of the time doesn't affect anything except for the looks.
Dee is offline
post #5 of 28 (permalink) Old 01-10-2007, 05:44 PM Thread Starter
Is this caused with the pull of the neck or just a natural crack in the body wood.
Zoot is offline
post #6 of 28 (permalink) Old 01-10-2007, 05:45 PM
Dee
The crack is usually only in the paint, not the wood. Still the neck pocket should be inspected to ensure there's no crack in the wood. Remove the neck and check it out.
Dee is offline
post #7 of 28 (permalink) Old 01-10-2007, 06:12 PM Thread Starter
Well i just took a look at the other side of the pocket and found this.
Maybe you can just see it.Been out on the lash tonight so it maybe vague.
Zoot is offline
post #8 of 28 (permalink) Old 01-10-2007, 06:15 PM
jaxadam's Avatar
That doesn't look all that too terribly bad. I think you could live with it. Take the neck off and take a good look, but it looks pretty normal to me.
jaxadam is offline
post #9 of 28 (permalink) Old 01-10-2007, 06:21 PM
Dee
Yep, this is common.
Nice JEM's, btw.
Dee is offline
post #10 of 28 (permalink) Old 01-10-2007, 06:33 PM
if it ain't broke don't fix it
Bookshelf is offline
post #11 of 28 (permalink) Old 01-10-2007, 06:49 PM Thread Starter
It is broke.
Thats why i'm asking if i should fix it.
Zoot is offline
post #12 of 28 (permalink) Old 01-10-2007, 07:05 PM
Ayrton's Avatar
Well in order to repair the crack (if it is in the wood) you will have to be able to separate it enough to get some glue in there. If the crack is in the wood, and you can only get a minor amount of separation, use some water thin CA glue (super glue) and clamp it until the glue cures. However if the crack is in just the paint, leave it alone.
Ayrton is offline
post #13 of 28 (permalink) Old 01-10-2007, 07:35 PM
It doesn't even sound like we've ascertained whether the crack is just a finish crack or it's actually in the wood. If it's just in the finish then it's nothing to worry about.
Andelusion is offline
post #14 of 28 (permalink) Old 01-10-2007, 08:07 PM
jaxadam's Avatar
Originally Posted by Zoot View Post
It is broke.
How is it broke?
jaxadam is offline
post #15 of 28 (permalink) Old 01-10-2007, 08:25 PM
Originally Posted by jaxadam View Post
How is it broke?
the crack
timi_h is offline
guitar tech , neck pocket crack
Jem 555 Neck Crack! Cobra Tech: Setup, Repairs and Mods 5 11-30-2005 06:42 AM
Ibanez RX 22 Fret Neck, Do They Fit a Standard Strat Pocket? CrossingStar All Other Guitars (including Prestige) 0 09-15-2005 09:32 AM
routing the neck pocket chef21 Tech: Setup, Repairs and Mods 4 03-14-2005 11:19 PM
JS guitar's--What is the neck pocket size? Lonely Raven Ibanez JEM, UV, JS & Other Signature Models 1 01-25-2004 08:26 PM
UV777PBK neck pocket number MALAM Ibanez JEM, UV, JS & Other Signature Models 0 01-20-2004 12:54 PM
HTML code is On
