Need help with body identification! UV7 RG550? - Jemsite
post #1 of 21 (permalink) Old 08-05-2010, 08:30 PM Thread Starter
I would like to know what kind of body this is, and what kind of tremolo can fit this thing.
It's got none of that "Jem tremolo cavity". But i'm also not sure if all the UV7, rg550, jem and all the ibanez with that kind of pickguard have the same body cavity and same pickguard size?
I just got this body off a local auction site for about $30 CAN. Im getting a friend to bring it back to Canada for me. I got an RG370DX neck i'm planning to install. Very excited =)
**********UPDATED**********:Here are the pics (with measurements too!)
THAT'S RIGHT BOYS AND GIRLS. YOU WERE ALL VERY SMART AND WAS RIGHT. ITS A CHIBANEZ, and it has a swimming pool pickup route =(
Anyways, i won't give up just yet. Right now i need to install a trem on it, and then do the pickups.Holes on neck would need re-drilling, since the neck is the real deal (RG370DX neck)
so what type of trem would fit on this? I'll be ordering on ****
aznricey is offline
post #2 of 21 (permalink) Old 08-05-2010, 08:58 PM
Re: Need help with body identification! UV7 RG550?
Looks like a either a lower end Rg body with a handle routed or just a copy body. I think it is routed for the TRS trem from the pics and it doesnt have a jem jack or a barrel jack on the higher end rg's but that is just from sight so don't quote me. Also the jack seems a little too high up on the guitar to be a standard rg but for 30 bucks it seems pretty good.
newbieguitarmaker is offline
post #3 of 21 (permalink) Old 08-05-2010, 08:58 PM
Yep, looks like its some type of an rg with a handle cut into it.
Jeminizer is offline
post #4 of 21 (permalink) Old 08-06-2010, 04:48 AM
That body does look shady. The back routing is not recessed - kinda like Fender-style. Most Ibanez back routing have recessed cavity, so that when you put on the cavity cover, it sits flush to the body back.
Also, the lower horn of the body, looks kinda rounded. Ibanez bodies have 'sharp edge' not like the one on this body.
The pickguard looks mis-shaped as well, especially the lower horn side.
My guess is that this is not an Ibanez body. Could be a Jem copy body, from some Jem knockoff. Even though it's cheap, you might run into some problems later when you wanted to assemble the RG370 neck to this body. The screw holes may not align, the neck pocket cavity may be to shallow or too deep - etc.
My 2 cents.
aj_foes is offline
post #5 of 21 (permalink) Old 08-06-2010, 05:48 AM
That trem route looks like a LoTRS route to me. Possibly an older Korean RG body.
littlephil is offline
post #6 of 21 (permalink) Old 08-07-2010, 03:57 AM
im 99% sure its a chibanez body.
brianxtr is offline
post #7 of 21 (permalink) Old 08-07-2010, 04:02 AM
Reviews: 98
Yeah--and a crappy refinished one at that.
AlaskaBat is offline
post #8 of 21 (permalink) Old 08-07-2010, 07:51 AM
looks like a chibanez, which would mean you wouldnt be able to install an rg neck on it without drilling holes in the neck, which to be honest doesnt seem worth doing.
tom1325 is offline
post #9 of 21 (permalink) Old 08-07-2010, 06:59 PM Thread Starter
But do you guys think the edge III trem locking nut that still remains on the neck would fit whatever tremolo i ended up installing onto the body?I hope I can actually install a trem that're availiable on **** for the body.
I'll definitely update you guys on this when I get it back next month or the end of this month.The neck had a cracked headstock before and it's been poorly glued, so it would make sense to put them together =)
aznricey is offline
post #10 of 21 (permalink) Old 08-07-2010, 09:58 PM
Reviews: 98
A nut is a nut. Nuts are sized to the neck, not the trem.
post #11 of 21 (permalink) Old 08-08-2010, 07:11 PM Thread Starter
Great, I just wanted to make sure that're no compatibility issues there at least.
I will check the cavity dimension right away when i receive the body thanks!
aznricey is offline
post #12 of 21 (permalink) Old 08-30-2010, 02:46 PM Thread Starter
Alright the suspense probably faded away. but here is the real thing, my friend helped me carry this body across the oceans from China to Canada lol
LONG AND BEHOLD, ITS A CHIBANEZ BODY =( booooo. But hey i can't give up!! I guess its a good practice for my very first build.
Any general directions would be greatly appreciated! I'll be installing the trem first (what trem can fit on this?) and then the elctronics last.
aznricey is offline
post #13 of 21 (permalink) Old 08-30-2010, 03:34 PM
Brosa's Avatar
I smell chibanez. Blegh...
Brosa is offline
post #14 of 21 (permalink) Old 08-30-2010, 04:58 PM
it does look cheap and cheerful.
jonnyboy mills is offline
post #15 of 21 (permalink) Old 08-30-2010, 05:23 PM Thread Starter
That's the right spirit! I mean, both my electric and acoustic are Ibanez. It would only make sense to get a NON-IBANEZ to be a chibanez~
PS: I'm Chinese =)
Seriously though, some constructive feedbacks would be appreciated. I just posted an ad to see if i get any offers on used ibanez trem systems. or floyd rose.
aznricey is offline
body id uv7 rg550 jem333
Looking for RG550 or 570 body WakingTheDemon Classified Ads: Guitars and Gear 7 12-22-2009 08:29 PM
RG550 body viciousfishes Classified Ads: Guitars and Gear 3 06-16-2009 11:16 AM
Wow another... RG550 identification plz Devon8822 All Other Guitars (including Prestige) 4 07-09-2007 02:47 PM
Wtb Rg550 body newbieguitarmaker Classified Ads: Guitars and Gear 1 04-15-2007 03:02 AM
FS: RG550 Project Body and RG Copy Body t1r12003 Classified Ads: Guitars and Gear 6 08-11-2006 10:49 AM
HTML code is On
