Need help, got bad stringbuzz. - Jemsite
post #1 of 15 (permalink) Old 12-27-2011, 04:22 AM Thread Starter
Hi all, first post here on jemsite.
I'we got a Jem/RG550 hybrid that has acted up on me and i need some help.
The guitar is a perleguitars jem body with whizard 1 neck and trem from a RG550, other hardware is dimarzio. I had the neck modification from original Square to AANJ made by the best guitarworkshop in Sweden (guitartech Åke Björnstad, gitarrmakaren)
Thing is, the guitar was working brilliantly until a couple of days ago. I hadent played it for a couple of days and suddenly it had a bad stingbuzz on the low e and a strings.
Since the guitartech has a two months waitinglist i thought i do a resetup myself.
I relaxed the trussrod alltoghether, raised the action rediculesly high, put new strings on but i still have a bad buzz.
When looking at the guitar the neck have a substantial bow. If i press fret 1 and 24 on the low e-string there is slighly less than half a creditcard thickness clearance at fret 5.
There is a buzz on all of the neck, from fret 1 to 15 so it's not a high fret.
I'm out of ideas, any thoughs of whats wrong here?
/Peter.
peter swe is offline
post #2 of 15 (permalink) Old 12-27-2011, 05:48 AM
Reviews: 4
Re: Need help, got bad stringbuzz.
If it's buzzing 1 to 15, chances are the neck is warped. Tighten the truss rod till the neck is dead straight and lower the 2 trem post and try again.
And by buzzing, it's buzzing clean or through the amp. If it isn't buzzing through the amp, it's not considered a fret buzz.
faekildare is offline
post #3 of 15 (permalink) Old 12-27-2011, 08:02 AM Thread Starter
I tightened the trussrod so now the neck is dead straight, i lowered the action to about 3mm at fret 12. It's still buzzing, i can clearly hear the buzz through the amp.
I guess i need to take it to someone who actuallt knows what he's doing.
post #4 of 15 (permalink) Old 12-27-2011, 08:37 AM
No...not yet. Be patient here. Now since you've got the neck back to near straight, if raising your trem studs doesn't help, then you may just need to put a shim in the nut...
TMatt142 is offline
post #5 of 15 (permalink) Old 12-27-2011, 09:32 AM Thread Starter
Ok. I gotta try to get a hold of shims then. Thanks.
post #6 of 15 (permalink) Old 12-27-2011, 09:34 AM
make shims cheaper
cut a coke/pepsi can open
ibanezcollector is offline
post #7 of 15 (permalink) Old 12-27-2011, 10:05 AM
Reviews: 4
Yep. Shimming the nut is a remedy for first few frets buzzing. That should solve the problem. If that still doesn't work, try using a mallet and knock all the frets in, making sure that the frets at all seated properly.
post #8 of 15 (permalink) Old 12-27-2011, 11:59 AM
Do not do this, re seating a high fret is more involved than whacking it with a hammer.
musikron is offline
post #9 of 15 (permalink) Old 12-27-2011, 12:28 PM
RGTFanatic's Avatar
LOL...I use a 2lb sledge on mine ALL the time
Guys, I can tell you from experience. If the OP can't find an obvious problem himself, He's far better off bringing it to a luthier to get things sorted out. The way his post reads, there are a plethora of other possible causes. Trying to repair any one of them could result in a useless neck.
RGTFanatic is offline
post #10 of 15 (permalink) Old 12-27-2011, 01:06 PM
Agreed, reading stuff on the internet is fine and dandy, but nothing can compare to years of hands on experience. And 9 times out of 10, someone shooting in the dark with no real idea of whats going on will only make matters worse. If you don't know WHY something is happening, you will never be able to fix it.
musikron is offline
post #11 of 15 (permalink) Old 12-27-2011, 01:33 PM
RGTFanatic's Avatar
Nuff said!!!
post #12 of 15 (permalink) Old 12-27-2011, 01:34 PM
are you sure its the strings buzzing ?
sounds like the bridge could be loose,
or maybe a loose pickup is resonating at low frequencies ?
LostInRockFormations is offline
post #13 of 15 (permalink) Old 12-27-2011, 01:38 PM
RGTFanatic's Avatar
or a stud anchor has broken loose, or the neck has twisted, or the scarf has swollen/shrunk, or nothing has changed other than whether, or.............
Your suggestions are good ones, but the OP needs a luthier to at least have a good long look at it.
post #14 of 15 (permalink) Old 12-27-2011, 01:48 PM
Reviews: 11
@Peter Swe:
If you do take it to a luthier (any good one. Don't wait 2 months for that other guy), see if you can hang out and watch what he does. That's a great way to learn to do it yourself!
D.M.RG7620 is offline
post #15 of 15 (permalink) Old 12-27-2011, 02:36 PM Thread Starter
Yea, thanks a lot for the input everyone!
I will take it to someone that has a lot more skill than i do. I have a basic understanding of how to set up a guitar, trussrod adjustment, string height and stuff like that but this is a bit over my head. I'm gonna try to find a skilled luthier other than the guy who built the guitar for me. He is as good as they get but there are alot of folks that want his services.
I'l check in later with an update, i doubt i will get a hold of a luthier now during the hollidays.
/Peter.
HTML code is On
