Need Help! Loss of Sustain on Jem. - Jemsite
post #1 of 16 (permalink) Old 03-03-2004, 05:16 PM Thread Starter
I have lost about 80% of sustain on my G string, I have a 90th Jem has anyone had this problem and if so have can I solve it. Is it the Pickups or Bridge?[/b]
clintalan is offline
post #2 of 16 (permalink) Old 03-03-2004, 05:51 PM
something could be obstructing the string. check for sharp edges on the bridge, at the nut etc. If there's nothing there, it could be the pickup.
don't know how to test that though.....
davester1234 is offline
post #3 of 16 (permalink) Old 03-03-2004, 06:12 PM
Make sure the saddle isn't a bit loose.
Rich is offline
post #4 of 16 (permalink) Old 03-03-2004, 06:27 PM Thread Starter
everything is smooth on the nut and saddle and nothing is loose
post #5 of 16 (permalink) Old 03-03-2004, 06:29 PM
Did you try a new string?
Rich is offline
post #6 of 16 (permalink) Old 03-03-2004, 07:09 PM Thread Starter
It's really strange I change my strings every four days because I play so much, so it has a band new set on it, but it has been doing this for awhile now had it has been steadly getting worse.
post #7 of 16 (permalink) Old 03-03-2004, 08:02 PM
why don't your try turning up the volume and tapping the magnet on each of the pickups.
maybe you'll be able to hear some kind of difference, which might reveal the culprit.
post #8 of 16 (permalink) Old 03-03-2004, 09:20 PM Thread Starter
They all pop the same man. No change from what I can see.
post #9 of 16 (permalink) Old 03-03-2004, 10:57 PM
is something on the fretboard obstructing the string from resonating?
If not then it sounds like one of your pickups is screwed
post #10 of 16 (permalink) Old 03-04-2004, 01:28 AM
Fry
Is your sustain the same on all the pickups?
Fry is offline
post #11 of 16 (permalink) Old 03-04-2004, 11:53 AM Thread Starter
Yes, I have the same loss on every pickup, but some notes are worse than others like D - A frets 5 - 14 seem to be the worse, there is no fret buzz or contact with the string though when fretted.
post #12 of 16 (permalink) Old 03-04-2004, 01:31 PM
sounds similar to a problem I had with my RG550, turned out to be a faulty Tone control
MALAM is offline
post #13 of 16 (permalink) Old 03-04-2004, 04:23 PM
Number one how low is your action? ANd how much bow do you have in your neck? Im curious as to how tight or loose the trussrod is on that guitar as well. If you have another ibanez edge equipped guitar i would trade out the saddle to see if that fixes it, who knows it could be cracked underneath or or anything.
sniperfrommars1 is offline
post #14 of 16 (permalink) Old 03-05-2004, 01:11 PM Thread Starter
Neck is flat no bow action is realitvily high I'm not positive of the exact settings.
post #15 of 16 (permalink) Old 03-05-2004, 03:58 PM
umm the neck should have some bow, its virtually impossible for it to play well without it. Fret the guitar at the 12th fret and tell me how much space you have between the string and the 5th and 24th frets
equipped guitar , fret buzz
Loss of sustain at the 12th fret and above... Lonerider Tech: Setup, Repairs and Mods 7 08-02-2011 09:58 AM
Teflon tape and loss of sustain/tone? kokyman Tech: Setup, Repairs and Mods 10 02-17-2011 11:59 AM
Hearing Loss Stringz Off-topic / Miscellaneous 25 01-21-2010 03:56 PM
sustain loss on high frets Orochimaru Tech: Setup, Repairs and Mods 10 12-18-2008 10:59 PM
job loss shredmaster Off-topic / Miscellaneous 24 08-17-2007 11:27 AM
HTML code is On
