Need help with measures on my JEM style project - Jemsite
post #1 of 5 (permalink) Old 09-07-2016, 09:15 AM Thread Starter
Hello everyone, I am making templates for my JEM style build. I have that old picture of JEM777 blueprint as a base of my templates. I have calculated and measured everything and came up with a conflict of numbers on where the neck should be.
So basically I have scale length of 648mm (roughly about 25,5 inches) and edge installing manual says that on 25,5" scale, tremolo mounting posts should be placed 637mm away from the edge of fingerboard.
Then there is that basic idea that neck pocket ends exactly where 16th fret is on the neck. 16th fret is 390,841 mm away from the nut.
1) Blueprint says that distance from the center of posts to the edge of neck pocket is 245mm. When I subtract that fret distance from post distance result is not 245mm, it`s 246,16 something. With exact scale (25,5"-647,7mm) distance grows even higher.
2) Is Ibanez toplok the same size as any locking nut ? Width 43mm and depth about little over 15mm? I don`t have any parts yet...
I have Floyd Rose bridges and I know you can adjust the intonation but I would still like to try and make it as accurate as I can. Also goal is not to make an perfect copy of Ibanez JEM but my own guitar.
Where am I going wrong ? Thanks
LiqoricePete is offline
post #2 of 5 (permalink) Old 09-08-2016, 02:15 PM
Re: Need help with measures on my JEM style project
Why are you complicating so much ?
Just make the neck pocket, insert the neck then measure 637mm from the nut to get the posts at the right place.
mtc777 is offline
post #3 of 5 (permalink) Old 09-08-2016, 03:39 PM Thread Starter
Yeah I quess you are right. Maybe it`s because I have been staring those plans and not started to build body yet.
Then again I was trying to figure out templates so everything would be already thought and measured. Would be cool to have accurate templates but maybe it would just make me cut without thinking. This is my first proper build and I don`t want to ruin it from the beginning.
Thanks for your reply.
post #4 of 5 (permalink) Old 09-08-2016, 06:09 PM
Get on with it ! One way to ruin a build is by over thinking everything
Zoot is offline
post #5 of 5 (permalink) Old 09-09-2016, 04:00 AM Thread Starter
Though love is it ? That`s just what I needed
build question , build your own clone , build your own guitar , diy
my JEM style build project thing hachimako Ibanez JEM, UV, JS & Other Signature Models 13 03-13-2013 05:11 PM
Changing trem in Jem style project guitarist scott050366 Tech: Setup, Repairs and Mods 5 03-12-2012 09:30 PM
New Project started..JEM style nato101010 Ibanez JEM, UV, JS & Other Signature Models 128 08-22-2011 03:28 AM
[YouTube] My attempt at on Troy Stetina's Drastic Measures Scali Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 3 03-09-2011 04:22 PM
FS: One of a kind Jem style project dannybigtime Classified Ads: Guitars and Gear 1 04-25-2009 11:08 AM
HTML code is On
