Need replacement nut for my chromeboy - Jemsite
post #1 of 4 (permalink) Old 08-13-2003, 05:58 PM Thread Starter
MoT
The fifth and sixth string part of the nut on my chrome boy just will not tighten... One more millimetre would do it as most of the threading is intact. Is there a way around this without replacing the nut (or putting lighter strings on)? I use a 36 and a 46 for the top two strings.
If I were to replace the nut, where can I order one online?
What's the specs on the nut on the chromeboy?
Helllllp!!!!
MoT is offline
post #2 of 4 (permalink) Old 08-13-2003, 06:01 PM
Depends on how many threads you have from the bottom of the bolt, you can get a longer bolt and grind it down to maybe grab an extra thread or 2, if you have the room between the bolt and the wood. Otherwise I have 10th nuts in stock.
Rich is offline
post #3 of 4 (permalink) Old 08-13-2003, 06:10 PM Thread Starter
MoT
Bolts
I just need a longer bolt by the looks of it. The threads near the surface just aren't gripping. I'd need 1-2mm longer on the bolt to go through to hold the strings in place.
Do you ship to outside of the US? I'm in Ireland
MoT is offline
post #4 of 4 (permalink) Old 08-13-2003, 06:11 PM
Hardware store. I only have factory bolts.
Rich is offline
chrome boy
WTT- Chromeboy for Chromeboy julio Classified Ads: Guitars and Gear 0 10-07-2007 06:12 AM
Js9 or chromeboy Anton Ibanez JEM, UV, JS & Other Signature Models 10 11-21-2002 05:27 PM
H-S-S Chromeboy..??? Kremlin Ibanez JEM, UV, JS & Other Signature Models 2 09-22-2002 10:19 PM
New Chromeboy's for Joe sparrow Ibanez JEM, UV, JS & Other Signature Models 18 08-28-2002 01:03 AM
HTML code is On
