New Jem/Edge Pro not staying in tune - Jemsite
post #1 of 9 (permalink) Old 05-10-2010, 09:53 PM Thread Starter
Anyways, brand new 77vbk off the floor, setup was horrible Felt like I was driving through gravel, do these ship with 10's on em? I put some 9's on her and did a proper setup right away but this edge pro keeps going out just a bit when I really dig in, even tho she's locked up tight. Anyone else having trouble with the edge pro? Also, can I swap it with an edge without modding, ..anyone know?
Supatones is offline
post #2 of 9 (permalink) Old 05-10-2010, 10:05 PM
Reviews: 37
Smile Re: New Jem/Edge Pro not staying in tune
did you stretch the 9's properly ? and no quick swap for the ep . it is a great trem though i have all 3 edgepro edgelopro and edge all are great. also the angle might be wrong go to ibanez rules at top click on setup then trem angle .
andrewsfury is offline
post #3 of 9 (permalink) Old 05-11-2010, 05:51 AM
Tank's Avatar
Reviews: 65
By the sounds of it, you might have to do a complete setup.
Go to ibanezrules.com and follow the setup instructions there LINE BY LINE.
Its a huge pile of work, but it will pay off.
If setup wrong the Edge, Lo-Pro and EP will not stay in tune, same with all Floyds. So changing the trem wont do any good in that cases and the EP is a nice and good trem.
Tank is offline
post #4 of 9 (permalink) Old 05-11-2010, 01:11 PM Thread Starter
Thanks guys! The trem is level no concern there however, I was checking out Ibanez Rules as per Andrews advice and read up on tuning...realized that I never tightened the lock nut screws when I did the setup, they were considerably loose. Seems like its holding much better now, another couple hours on her and Ill know for sure, loose nut would certainly account for poor tuning. Ill be back with my results. Thanks again.
post #5 of 9 (permalink) Old 05-11-2010, 09:56 PM Thread Starter
Update, Its solid now, tune is holding perfectly even after heavy ****ing, I have had to tighten those two screws behind the nut on my other Ibbys too ..those suckers come loose after a bit.
post #6 of 9 (permalink) Old 05-27-2010, 04:46 PM
+1 on the lock nut screws. I went through this once. the local luthier added a piece of duct tape to raise the nut and he didn't tighten the screws properly.
Like they say - sometimes, its better to do things yourself.
Project.Music is offline
post #7 of 9 (permalink) Old 07-11-2010, 09:33 AM
+1 On doing all the steps. Also, adding the chapstick seemed to work big time. I never thought my new RG would stay in tune and NOW it does. Thanks to all of the posts regarding this.
andrewpmast is offline
post #8 of 9 (permalink) Old 07-11-2010, 10:28 AM
Reviews: 21
I'd start with the tension springs at the back of the guitar for the trem. Get a tuner. If you keep falling flat after tuning all six strings, *slightly* tighten the two screws for the springs. If you keep going sharp, *slightly* loosen the springs. If you don't cancel out these forces, your trem will never stay in tune.
Continue with setup from there. And follow Rich's setup section at ibanezrules.com.
mike570 is offline
post #9 of 9 (permalink) Old 08-07-2010, 06:17 PM
Great tip!
SGplayer is offline
jem guitar
Low E string not staying in tune! AnDr3wYoN Tech: Setup, Repairs and Mods 7 04-11-2009 08:41 PM
i need help with staying in tune... bjamin86 All Other Guitars (including Prestige) 1 01-17-2007 11:18 PM
TRS Pro not staying in tune - please read PacificaJonny Tech: Setup, Repairs and Mods 1 02-22-2006 01:01 AM
Edge Pro II not staying in tune TheSlowChemical Tech: Setup, Repairs and Mods 6 04-17-2004 03:25 PM
Not staying in tune - and now I know why!!!! littlegreenman Ibanez JEM, UV, JS & Other Signature Models 7 10-16-2001 12:40 AM
HTML code is On
