NGD - 1991 UV7BK Green Dot + Finish help! - Jemsite
post #1 of 20 (permalink) Old 10-12-2010, 04:30 PM Thread Starter
Reviews: 9
Ok, we don't get NGD threads very often here, so I thought I would do one :-)
Some of you may know I've been looking for a guitar recently. Well I found one (well, two, but more on that later) and it finally arrived yesterday after two painful weeks of waiting it to come from across the Atlantic - a week of which it spent sat in customs...
Here it is, all the essentials are original (there's an odd nut pressure pad, and different neck plate, switch tip and the output jack).
If anyone has any suggestions as regards the finish, which you may be able to see is quickly crackly in places and looks like it's been exposed to some serious damp, I'd appreciate it. There a quite a few hairline very small, shallow finish cracks that seem to follow the grain - would T-Cut or something buff these out?
Also, I'm pretty sure these things came with a barrel jack (JEM type) right?
1991 Ibanez UV7BK Green Dot Universe.
I just love this thing! Every time I catch a glimpse of it, I have to go pick it up!
Fun111 is offline
post #2 of 20 (permalink) Old 10-12-2010, 06:44 PM
Reviews: 34
Re: NGD - 1991 UV7BK Green Dot + Finish help!
Looks cool!
I don't think that t-cut will take out cracks. Shallow scratches in the clear coat only, but cracks probably not. If that is the only issue then I would say give it a go as it doesn't actually hurt.
This cracking or wrinkling looks a bit strange. It almost looks like the body wasn't sealed or the grain filled correctly prior to painting. Is there any chance that it was a refinish? Maybe it is just the pics, but it the paint seems to have that grainy look you sometimes get from rattle cans.
I have seen the markings of linear grain or glue joins coming through on some other guitars, generaly on refinishes or cheaper models (which this clearly isn't!) but never on a high end Ibanez.
If it has been subjected to damp it could have swelled and shrunk a little leaving the creasy, but I would expect to see more rust on the hardware unless it has been replaced.
Either way I bet it plays well. Enjoy!
nickcoumbe is offline
post #3 of 20 (permalink) Old 10-12-2010, 07:22 PM
I'm almost positive that's a poor quality refinish. I'd strip the body and have it professionally painted.
Takin' a Ride is offline
post #4 of 20 (permalink) Old 10-13-2010, 03:12 AM
its possibly been refinished and the paint has dropped back, this is the most obvious reason I can think of, its difficult to tell without looking at it in the flesh.
Best thing you could do is put the guitar outside in natural sunlight, turn off the camera flash and take some more photographs.
jonnyboy mills is offline
post #5 of 20 (permalink) Old 10-13-2010, 03:40 AM
NSR
The finish does look kinda funky. Maybe the suggestion of a refinish is accurate? I don't think I've seen paint like that on an Ibanez either.
I can't think of any reason why it shouldn't have a regular barrel jack. It is possible that it was replaced with a stereo jack. Take the jack cover off and check...if so then chances are it may have had EMGs fitted in the past.
NSR is offline
post #6 of 20 (permalink) Old 10-13-2010, 03:57 AM Thread Starter
Reviews: 9
I think it's an incomplete refin, I'll take some pictures then wetsand and cut it in this afternoon, should be able to gloss it out again.
I didn't pay much for it for exacty this kind of reason lol.
Anyone know anyone in the UK who'll refinish the body if I decide to do that?
Fun111 is offline
post #7 of 20 (permalink) Old 10-13-2010, 05:55 AM Thread Starter
Reviews: 9
It turns out that it is a barrel jack, it jut has a different tip. The pickups are definitely of the period, as you can tell by the pole pieces on the single coil, and I removed the pickguard last night and I wouldn't be surprised if it was the first time it had been since it was made. The finish was immaculate underneath an even stuck to the pickguard in places. I think the finish is just badly maintained :-S The wear in the finish around the pickguard also matches that onthe pickups and pickguard. I'm starting to doubt this is a refin.
I learn something new about this thing every day lol. It plays and sounds awesome though, I love it to bits, cosmetics would just be a bonus.
Fun111 is offline
post #8 of 20 (permalink) Old 10-13-2010, 01:16 PM Thread Starter
Reviews: 9
I've got some t-cut, and have given it a bit of elbow grease - I don't appear to be getting very far...
How do other people do this? I'm not leaving it on or anything, literally just applying to a cloth and working in in a circular motion...
Cheers.
Fun111 is offline
post #9 of 20 (permalink) Old 10-13-2010, 01:21 PM
Reviews: 98
I think a strip and refinish is in order! It looks great, but if you want a "proper" finish just redo it.
AlaskaBat is offline
post #10 of 20 (permalink) Old 10-13-2010, 05:02 PM
The paint was probably stuck to the pickguard because some guy rattle canned the body and then put the pickguard back on too soon. Seriously, that's not a factory finish. If it were, it would be hands down the worst one that ever left the factory.
post #11 of 20 (permalink) Old 10-13-2010, 05:21 PM
I own a PWH, my second Universe will be a Black w/ green dots !
Congr(een do)ats !
Agent540 is offline
post #12 of 20 (permalink) Old 10-13-2010, 05:46 PM
Reviews: 98
If you ever want to get rid of that--let me know.
post #13 of 20 (permalink) Old 10-14-2010, 05:21 AM Thread Starter
Reviews: 9
Ok so yesterday I decided to experiment.
I figured if it all goes tits up I'm gunna refinish it anyway.
I applied a sh!t load of black T-Cut to the top, worked it in (circular motion) and removed excess, applied Meguiar's 'Swirl and Haze Remover' then Meguiar's 'Mist and Wipe' and after repeating this about 3 times, it's looking a lot better. This is definitely a refinished body, more on that in a minute. Doing this took away a large portion of the grain lines (though still vissible in the right light) and 'Orange Peel' pitting, but it's far from a mirror finish.
Then I had a go a wet sanding a portion of the back. I've never done this before on such a large portion, only ever to touch in small portions of clearcoat. I started at 2000, went down to 1500, then back up to 2000 and then in 1000 grit steps to about 8000, applied T-Cut and did as above. Repeated this twice and that's much much closer to that real mirror finish, however being as I haven't done this before, it's marginally more grey than the rest of the body. Part of this is to do with the rest of the body looking almost wet and sticky - horrible.
This is the first time I've really examined the finish and having seen a guitar progress through the finishing process, I am certain this has been aerosoled with some sort of acrylic based paint then not finished. The paints been applied and sort of sanded in but not all the way. I want to try everything I can to recover the finish before I drop 200 on refinishing it, mostly because it's good practise, but I also don't want to spend that sort of money!
Anyone got any tips for wetsanding? Can anyone go through the procedure or recommend any products? The finish gets better each time I repeat the process however I feel I'm missing a final step that brings it back and fills in the scratching....
Pic's to come.
PS You guys wait til you see the PWH, it's the original finish but it is in BAD shape, lol. However bad you think it is, it's way worse.
Fun111 is offline
post #14 of 20 (permalink) Old 10-14-2010, 07:19 AM
Pic's to come.
PM sent.
post #15 of 20 (permalink) Old 10-18-2010, 07:07 AM Thread Starter
Reviews: 9
I've started wetsanding the back. It's getting very close and in some light is what you'd call 'mirror finish', however I'm still seeing some scratching. Before take it to my luthier friend, anyone any last suggestions?
I went from 1500 grit up to 3000, T-Cut then Meguiars swirl and haze remover. The finish is flat, just showing scratches - did I just not 3000 it for long enough?
Fun111 is offline
green dot , ibanez universe , ibanez uv , universe
FT: 1991 Ibanez Universe UV7BK Green Dot JPM7stringfan Classified Ads: Ibanez JEM/UV Guitars 10 11-21-2010 06:43 PM
FS: Ibanez Universe UV7BK Green dot (1991) shreddyknight Classified Ads: Ibanez JEM/UV Guitars 3 08-16-2010 08:51 AM
NGD, 1991 Green Dot UV7BK! JPM7stringfan Ibanez JEM, UV, JS & Other Signature Models 17 05-10-2010 09:47 AM
FS: 1991 UV7BK W/Green Universe Rodney James Classified Ads: Ibanez JEM/UV Guitars 6 11-12-2006 08:03 PM
FS: 1991 UV7BK (green dot) in good condition w/ case toddmiro Classified Ads: Ibanez JEM/UV Guitars 4 06-22-2006 01:19 PM
HTML code is On
