Ok, I have a retarded question.... - Jemsite
post #1 of 2 (permalink) Old 07-19-2013, 09:08 PM Thread Starter
jb4674's Avatar
Reviews: 18
I haven't played my JS1000 in a while and it's been sitting in my guitar room untouched on a Hercules stand. Lately, I've noticed that every time I switch pickups (bridge or neck), I get an annoying buzzing sound and it goes away when both pickups are engaged (middle position). I was also having some crackle on the pots (indicative of dirty pots), so I sprayed some Deoxit D5 in there and now, the pots are nice and silent when turning the volume up or down and adjusting the treble. I sprayed some Deoxit on the toggle switch as well in hopes that this noise was going to go away but, it's still there (I sprayed it from the top of the switch because I didn't know how else to get it in there). All the wiring in the guitar is stock and I'm kinda stumped as to what it could be. Is there a better way to spray the contact cleaner in that switch? Or should I do it from the bottom? I noticed that there are 3 tiny holes on the bottom of that toggle switch....
In terms of equipment, this is what I've used:
Guitar into Peavey JSX Head (noise)
Guitar into RJM Rack Gizmo and Effect Gizmo into Peavey JSX Combo (noise)
Guitar into Eleven Rack into Tech 21 Power Engine 60 (noise)
Cables used:
Mogami Platinum 20ft with Neutrik Silent Plug on one end and regular Neutrik Plug on the other end (noise)
Fender Standard Whirlwind instrument cable (noise)
Power:
Furman PL-8C
I've never had an issue with this guitar in terms of noise until now and the same can be said for the cables.
Any ideas would be helpful.
TIA
This video shows exactly the type of noise I'm hearing. Fast forward to 2 minutes for the bridge (noise), 2:24 for both pickups (no noise), and 2:39 for the neck (noise again). Although this isn't the same guitar, the same type of noise occurs, which begs the question.. Is the same symptom occurring in any guitar with a HH configuration? And, if so, is that something that just can't be remedied?
http://www.youtube.com/watch?v=fWQCmfFyaF0
Jimmy
jb4674 is offline
post #2 of 2 (permalink) Old 07-19-2013, 11:48 PM
Re: Ok, I have a retarded question....
it may be a bad connection on a ground wire. this can happen by itself over time with a cold solder joint or corrosion. but if the noise goes away when both pick-ups are on then maybe you simply need to replace the switch. things with moving parts wear out sometimes. also, try spraying the knobs again and exercise the push-pull when you do it.
woodman300 is offline
js1000 noise
Is this retarded or what? microdmitry Off-topic / Miscellaneous 24 05-09-2008 03:54 PM
My retarded monkey joeydego Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 4 02-14-2007 05:53 AM
f-space question, and pickup combination question Jing Tech: Setup, Repairs and Mods 14 05-03-2006 02:50 PM
777DY wiring question(parallel/series) +volume question mko Pickups & wiring 0 11-16-2004 07:06 AM
HELP!!! *I think i might be retarded shawn Gear, Equipment, Recording & Off Topic 19 01-08-2002 10:48 AM
HTML code is On
