Orientation of Drill holes for neck HB wires on FP JEM? - Jemsite
post #1 of 3 (permalink) Old 10-30-2007, 12:17 PM Thread Starter
Question Orientation of Drill holes for neck HB wires on FP JEM?
I want to know how the Wires are drawn/Positioned from the neck HB pickup to the Control cavity on a FP JEM or GMC.
I can sure guess how it is drilled, but it would be good to know how Ibanez did it.
As you can see here there is a wire going down at the top. Where it goes from there in the question.
http://www.ibanez87.it/italiano/altr...merlin-18.aspx
There is a lot of grounding screws here too. Do you ground each Pickup separately at different locations?
Metallion is offline
post #2 of 3 (permalink) Old 10-30-2007, 12:44 PM
Re: Orientation of Drill holes for neck HB wires on FP JEM?
they drilled with a long drill bit right thru the "wall" between the neck-joint cavity and the neck pickup cavity. you can see the hole in the right side of this pic:
that's the hole. it runs straight thru all of the pickups cavities.
that's a ground wire. it's soldered to a pot.
i never do. i just solder pickups' ground wires onto a pot, that's all.
nuno is offline
post #3 of 3 (permalink) Old 10-30-2007, 03:44 PM Thread Starter
The wires I mention and want to know the Orientation of are the vaguely visible BLACK ones disappearing down in the uppermost ADJUSTMENT CAVITY (at the top of the PICTURE at 11 O'clock).
Does this ground screw also go to a Pot?
Why do they place the Pot Grounds in such places?
neck pickup , pickup cavity
Problem with 2003 7Vwh JEM, Possibly New Edge Pro Trem Fault leonard deroma Ibanez JEM, UV, JS & Other Signature Models 89 06-18-2007 10:57 AM
Next Jem to buy after a Jem 10th? hamand Ibanez JEM, UV, JS & Other Signature Models 35 03-18-2007 10:01 PM
Locking nut screw holes, drill them before or after shaping? SilverSurfer2 Tech: Setup, Repairs and Mods 1 03-17-2004 07:24 PM
Is it safe to drill a couple of holes in the trem block? caprile Tech: Setup, Repairs and Mods 5 09-26-2003 02:28 AM
What is the best way to drill neck holes in new body..... SilverSurfer2 Tech: Setup, Repairs and Mods 10 04-14-2003 05:41 PM
HTML code is On
