Pick-up squealing problem - Jemsite
post #1 of 6 (permalink) Old 06-08-2006, 04:13 AM Thread Starter
Unhappy Pick-up squealing problem
Hi guys. just wondered if any of you can help me.
I have a JEM 7Vwh and i'm having some real sound issue when using distortion and the bridge pick-up. as soon as i select it, there is an extremely high pitched squeal (ver unpleasant)..................i've tried different leads, i've stood at the other side of the room using a radio mic, i've tried adjusting the pick-up height, and I've rolled back on the gain (which i don't really wanna do) but nothing seems to work. is this a common problem and do you have any ideas on how i might solve it.
Thanks in advance for any help or advice you may offer
Cheers
Neil
elephantlugs is offline
post #2 of 6 (permalink) Old 06-08-2006, 09:09 AM
Re: Pick-up squealing problem
Hey Neil.
That's weird. My friend has a Mex Fender Strat that used to do that. It seems that your pickup is excessively microphonic. I'm not sure what would cause that... I would've suggested lowering your pickup, but you've already tried it and it doesn't work. Could it maybe just be a duff pickup that needs changed? How long has this been going on?
On second thoughts you may have a shielding or earthing issue. It could be interference from electrical appliances, e.g. lights, TVs, digital alarm clocks... stage lights are also notorious for causing noise.
Hope this is of some help
Shredder87 is offline
post #3 of 6 (permalink) Old 06-08-2006, 11:37 AM Thread Starter
it started at practice last night. i was wondering if it could've been the amp but it doesn't seem the case..........looks like i'll be buying new pickups by the sound of it. doh
i can't actually get the pick-ups any lower..............the screws would come out. ha ha.
i've stood well away from all sources of possible interference but it still seems to happen. was hoping it was just a wiring issue or somet cheap to fix. he he
Thanks for trying anyway shredder87, it's very much appreciated.
post #4 of 6 (permalink) Old 06-08-2006, 12:04 PM
Most likely the pickup has gone microphonic. Send it to Dimarzio with $25 and they will replace it. Call them for details.
Rich is offline
post #5 of 6 (permalink) Old 06-08-2006, 12:10 PM Thread Starter
Cheers Rich
Is there a place there'll be a place here in the U.K eh ????
how does it happen...............is there anything i need to do/avoid in the future ????
Cheers
Neil
post #6 of 6 (permalink) Old 06-08-2006, 12:31 PM
Got me on the UK.
Heat - bad. Melts the wax and exposes winding to each other, although not always the culprit.
Rich is offline
fender strat
Problem with 2003 7Vwh JEM, Possibly New Edge Pro Trem Fault leonard deroma Ibanez JEM, UV, JS & Other Signature Models 89 06-18-2007 10:57 AM
Saddle problem on Edge Pro ThomasBJ Tech: Setup, Repairs and Mods 11 04-12-2005 02:05 PM
JCM2000 DSL100 volume swell problem Joshka Gear, Equipment, Recording & Off Topic 40 04-14-2004 05:49 AM
Slippery pick problem keithb Gear, Equipment, Recording & Off Topic 21 09-05-2003 09:05 AM
Problem with Evo pick up of JEM 10th fabione Tech: Setup, Repairs and Mods 3 01-09-2003 08:57 PM
HTML code is On
