Position of Lower Horn on JEM 77FP ? - Jemsite
post #1 of 1 (permalink) Old 11-28-2008, 07:07 PM Thread Starter
Question Position of Lower Horn on JEM 77FP ?
What is the distance from the center of the neckplate to the tip of the lower horn on a JEM 77FP (or any old JEM)?
According to the Blueprint on:
http://static.keebali.com/jemsite.co..._blueprint.jpg
The Perpendicular distance of Centre to Horntip is ~116mm (4.567"), or 88mm (3.46") from body (neck joint side) to horntip.
It looks on most Floral Patterns, or just all JEMs, to be a greater distance than this.
Could anyone check this out what is correct?
The tip is 6mm below the body-neck-top according to the BP too.
Correct?
Outermost Horn-Curve is 135mm from Centre.
JEM Neck plate is 64 x 50.8mm (2.52 x 2"), right?
Anyone have knowledge on all this?
Metallion is offline
77fp , neck plate
I just killed my Apple Horn! casper777 Tech: Setup, Repairs and Mods 7 08-13-2007 04:37 AM
RG620x could i change the 2 position switch to a 3 position switch without any mod? supergirl20_06 Pickups & wiring 6 04-25-2007 06:12 AM
apple horn guitars straymond All Other Guitars (including Prestige) 11 06-26-2006 01:19 PM
Jemfest 2001 Videos to Change - lower compression = lower qu Gabe Nickelson Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 20 02-24-2002 01:05 AM
HTML code is On
