Problem with one harmonic - Jemsite
post #1 of 4 (permalink) Old 05-20-2003, 01:09 PM Thread Starter
Hey...
I've got a JEM 7 DBK and I have a problem with the harmonic on the g-string above the 5th fret.... this harmonic has no sustain as the other harmonics above this fret... I think the problem occured 2 string changes ago... can the string tensipn be the key?? My LoProEdge isn't perfect parallel to the body (on the low strings the distance is greater, on the high strings it's exactly 1mm(+-0,5mm)
thanks for helping
nxn-Matrix is offline
post #2 of 4 (permalink) Old 05-20-2003, 03:00 PM
the harmonics are located on mathematical defined places on the string, the nodes of the waves. If the harmonic isn't exact above the 5th fret, try a litlle higher or lower. I hope you find some harmonic. Depending on the result, your must change the total string length on your bridge...longer or shorter.
Maybe there is a problem that your guitar absorbs the exact frequency of that harmonic (the opposite of resonance) so it doesn't sount as loud as the other harmonics.
jemke is offline
post #3 of 4 (permalink) Old 05-20-2003, 03:20 PM
Try switching to a different pickup. The bridge position Duncan JB on my main guitar picks up a lot of harmonics that the neck position '59 doesn't pick up so well, and vice versa.
darren wilson is offline
post #4 of 4 (permalink) Old 05-22-2003, 03:16 AM
The first thing I would check would be the intonation. Your harmonic spots can "move" if your intonation is out. The intonation guide on the Ibanez page is quite accurate:
http://www.ibanez.com/support/howtos.asp#ati
-Lance
lance is offline
bridge position , high strings , low strings , neck position
Pinch harmonic problem!!! Hriatrenga All Other Guitars (including Prestige) 9 11-14-2017 02:49 PM
FS: Harmonic Converger $100 toneboy Classified Ads: Guitars and Gear 1 08-05-2009 09:08 PM
Most harmonic-full amp? twooos Gear, Equipment, Recording & Off Topic 40 10-23-2007 09:16 AM
To Artificial Harmonic or not... Reinder All Other Guitars (including Prestige) 10 04-30-2007 03:39 AM
harmonic problem - need some help here... johank Tech: Setup, Repairs and Mods 0 10-10-2001 02:50 PM
HTML code is On
