Push/Pull *volume* pot on JS1000? - Jemsite
post #1 of 7 (permalink) Old 06-28-2010, 12:31 PM Thread Starter
Hi all,
I recently acquired a JS1000 made in 2000 in mint condition, all stock (even still had the peel-off protectors on all the plastic parts). It has the coil tap on the tone knob as normal, but the volume knob is also a push pull pot. When engaging it I can hear no difference.
What gives? Factory error?
Also, what kind of trems were being used on the JS1000's back in 2000?
Thanks!
sbm
smallbutmighty is offline
post #2 of 7 (permalink) Old 06-28-2010, 05:36 PM
Re: Push/Pull *volume* pot on JS1000?
The push pull pot on the volume knob is a high pass filter, engage the coil split and roll the volume back with the volume in both positions and you will hear a difference, I never use the coil split without engaging the high pass filter. If you just play with the volume up full you won't notice any difference, it retains the clarity as you lower volume.
guitarnoize is offline
post #3 of 7 (permalink) Old 06-28-2010, 05:42 PM Thread Starter
When I opened that back and saw the caps I thought that's what it might be. Interesting that there is no mention of it in any JS1000 literature I've ever seen.
Thanks!
post #4 of 7 (permalink) Old 06-28-2010, 05:42 PM
Reviews: 59
Guitarnoize is perfectly correct. The difference is not as apparent if your volume is on full. However, rolling the volume back to 3 or so will allow you to hear a much brighter tone than with the knob pushed in.
smooth55 is offline
post #5 of 7 (permalink) Old 06-28-2010, 07:07 PM
jb4674's Avatar
Reviews: 18
It's too bad it only works on the coil-split mode.
Jimmy
jb4674 is offline
post #6 of 7 (permalink) Old 06-28-2010, 09:15 PM
Contributor
OCDemon's Avatar
It works without splitting the coils as well.
OCDemon is offline
post #7 of 7 (permalink) Old 06-30-2010, 11:39 AM
i have mine on all the time. just wired it that way and love it
Cornbread is offline
js1000 , push/pull , volume knob
Push/push and push/pull pots... Myst and rain Tech: Setup, Repairs and Mods 8 06-07-2009 02:11 PM
Push Pull volume pot EvoGiant Gear, Equipment, Recording & Off Topic 5 03-13-2009 11:34 PM
Js1200 Volume Push Pull liquid piece Ibanez JEM, UV, JS & Other Signature Models 4 01-22-2009 04:33 PM
EMG 89/85 wiring with push-pull volume pot Jacob K Pickups & wiring 7 11-27-2008 07:14 PM
Using volume/mini-toggle push/pull pot as a pickup switcher? guitarkatana Pickups & wiring 2 01-26-2004 10:57 PM
HTML code is On
