Are Pyramid Inlays made of 1-pcs-inlays or parts? - Jemsite
post #1 of 9 (permalink) Old 02-14-2008, 10:09 AM Thread Starter
Question Are Pyramid Inlays made of 1-pcs-inlays or parts?
Are the clear inlay plastics on the JEM Pyramid necks mounted in one-pieces or in parts, one part for each different colour - paper bit it covers?
If they are in parts, the adjacent sides must be (are) glued together, or?
Anyone have experience in mounting/glueing them?
Metallion is offline
post #2 of 9 (permalink) Old 02-14-2008, 10:31 AM
Re: Are Pyramid Inlays made of 1-pcs-inlays or parts?
One piece as far as I know and obviously the colored paper is different pieces. The other method is different pieces of colored plastic instead of clear pieces with colored paper which the pieces would just be glued into place, not necessarily glued togther per say, but glued into place like a puzzle piece.
screamndemon69 is offline
post #3 of 9 (permalink) Old 02-14-2008, 11:40 AM
Batchimp RG's Avatar
Not all one piece iirc, check with Andy7Jem.....
Batchimp RG is offline
post #4 of 9 (permalink) Old 02-14-2008, 11:42 AM
Originally Posted by Chimp RG View Post
AndyJem.....
Wheres my 7???
I'm not going to take the neck apart to find out I just play it
andy7jem is offline
post #5 of 9 (permalink) Old 02-14-2008, 11:47 AM
Originally Posted by andy7jem View Post
Wheres my 7???
You can tell by just looking at it, nan
post #6 of 9 (permalink) Old 02-14-2008, 12:07 PM Thread Starter
I have seen some DY (at Harris site?) with indications of multi-Parts assembly, not uni-pieces.
Wonder about the durability on this Piece-method, but as it all are sanded plane, maybe not.
To get rid of an annoying line in the inlay is the concern here.
Most bewildering is how they did avoid getting glue on the inlay paper.
post #7 of 9 (permalink) Old 02-14-2008, 01:37 PM
My DY ('88 ) uses individual pieces of clear for each color. If you just look closely and turn the guitar to the side a little, it's easy to see, because each section is a millimeter or so thick, so you can see the edges go down to the paper.
The fit is so good that I'd imagine there were large individual sheets of each color bonded to sheets of the clear inlay plastic, so that when cut to size, the paper and plastic were cut at the same time.
EDIT: A photo of mine:
ibanez otaku is offline
post #8 of 9 (permalink) Old 02-14-2008, 01:55 PM
Jaden's Avatar
you have probably seen this http://www.projectguitar.com/tut/3dinlay1.htm
Ive used solid pieces of coloured plastic and jointed them together before....
ive superglued them and yuo dont get a joint line, just a change of colour.
teh other way I suppose is to use acetone and "melt" the pieces of solid plastic together before sanding out imperfections....
ive never tried the vinyl under clear acrylic route... seems a little 'cheap' to me.
Jaden is offline
post #9 of 9 (permalink) Old 02-14-2008, 09:10 PM
That makes a lot of sense and probably is how they did them. It would save a lot of manufacturing effort.
ryanb is offline
WTB: 22 frets Ibanez AANJ Neck (Made in Japan) supergirl20_06 Classified Ads: Guitars and Gear 1 10-24-2008 08:00 AM
F/T or F/S Custom made 7/6 string double neck tobe Classified Ads: Guitars and Gear 0 01-13-2008 06:56 PM
What are vine inlays made of? MadeinJapan Ibanez JEM, UV, JS & Other Signature Models 21 04-02-2007 10:20 AM
Need suggestions for parts for my UV7BK'97 nmanel Tech: Setup, Repairs and Mods 4 01-25-2006 10:15 PM
Automotive plastic dye and pyramid inlays shredfingers Tech: Setup, Repairs and Mods 4 08-30-2002 10:05 PM
HTML code is On
