Question about the "Ibanez Jem" single coil pickup. - Jemsite
post #1 of 8 (permalink) Old 07-27-2011, 09:39 AM Thread Starter
I'm working on a parts list to rewire a buddy's '07 Jem to be like his old pink Jem ('8. The pink's single coil seems to be an "Ibanez Jem" pickup. Is a current Dimarzio HS-2 comparable and a good match for the PAF Pros that I'll be installing? Other viable options/matches?
Thanks folks!
clothwiring is offline
post #2 of 8 (permalink) Old 07-27-2011, 09:43 AM
Reviews: 5
Re: Question about the "Ibanez Jem" single coil pickup.
yes...the HS-2 is exactly what was IN the original JEM 777SK, as far as i am aware...HS-3 will be a better match sound-wise to the humbuckers, IMHO...
bobbydevito is offline
post #3 of 8 (permalink) Old 07-27-2011, 09:47 AM
HS-2 in single coil mode works well, or you could just use a DiMarzio ISCV2.
Algiman is offline
post #4 of 8 (permalink) Old 07-27-2011, 10:34 AM Thread Starter
Bobby, what about the HS-3 do you feel makes it a better match for the PAF Pros?
Algiman, can you direct me to some specs n the ISCV2? Thanks!
Good input thus far, I appreciate it.
post #5 of 8 (permalink) Old 07-27-2011, 10:47 AM
The ISCV2 is the part number for the Jem single coil. If you want a Jem pickup sound, then go for it.
If you want another pickup in there, then it won't really matter too much, but I'd try to get a high output model to avoid having it swamped by the paf pros.
GuitarBizarre is offline
post #6 of 8 (permalink) Old 07-27-2011, 12:03 PM
I agree. Really, any single coil will do. Mainly output is what you should pay attention to. Personally, I like the FS-1. I almost never use the middle pickup, but I like the idea of having an actual single coil wired with the split humbucker for more authentic quack and no hum.
RedTiger is offline
post #7 of 8 (permalink) Old 07-27-2011, 01:10 PM
I have a JEM single coil I got from another forum member a while back that I'm not going to use if you still want one.
EvilEmuOfDoom is offline
post #8 of 8 (permalink) Old 07-27-2011, 02:41 PM
I have a Rg550 that i put evos in and an hs-2 in the mid. Sounds great and is not overpowered by the evos so it should work fine with the pafs.
Playloud78 is offline
pickup replacement
Question about "Mighty Mite Motherbucker Pickup (Rear / Bridge)" AlaskaBat Pickups & wiring 1 03-04-2011 04:04 AM
WTB: Ibanez USA Custom "Street Wise"/"Streetwise" Powermetallist Classified Ads: Guitars and Gear 2 10-14-2010 11:43 AM
ever see a "JS1000" with black gloss, no "satch" inlay and a "J" ser. # IKE560 Ibanez JEM, UV, JS & Other Signature Models 2 04-11-2009 03:05 PM
D sonic = Single Coil + "Lipstick" pickup? Mr.WizardNeck Pickups & wiring 6 03-25-2009 12:46 AM
Differences between "IBZ INF1/INF2" and "Duncan Ibanez" pickups? Inzane All Other Guitars (including Prestige) 1 11-03-2007 12:15 AM
HTML code is On
