Question guys (an gals) - Strings on UV...again - Jemsite
post #1 of 8 (permalink) Old 08-31-2001, 12:01 AM Thread Starter
I know this was asked before, but I can't find the thread on this topic so here it goes:
I just got my first UV and it needs to be set-up real bad. I love using .10-.52 gauge strings. What is the gauge of string that I should use on my low-B?
Thanx a millon
30yroldpig is offline
post #2 of 8 (permalink) Old 08-31-2001, 12:11 AM
Hey, you're a Donnie head!
I'd go 62, the question is 4 springs or 5?
Rich is offline
post #3 of 8 (permalink) Old 08-31-2001, 02:49 AM
kennydoe's Avatar
the standdard d'addario 7 string .010 set has a .056 for the low B
sinc eyou're using heavy bottoms, you can go a little thicker than that, but I was told by a guitar tech that once you get past a certain point, you start going in to bass strings, which are a little harder to come by and are more expensive, yada yada yada.
d'add set is 10, 13, 17, 26, 36, 46, 56.
Hope this helps
~Kenny
kennydoe is offline
post #4 of 8 (permalink) Old 09-02-2001, 11:34 AM Thread Starter
Thanx for the responses guys.
Rich , when you say 4 or 5 springs, are you reffering to the three behind the back plate keeping tension on the floyd? In that case, right now I have three. What kind of difference would a fourth or fifth spring achieve?
I really want the tone of .10-.52 so I will try a .62.
Or should I simply stay with the standard .10-.46 7 string set, and avoid any potential problems?
BTW, what is a donnie head?
post #5 of 8 (permalink) Old 09-02-2001, 12:47 PM
You use 3 springs with a 10-52 on a 6 string? Your claw must be screwed all the way in! You should need at least 4 springs using a 10-62 on a 7 string.
Your avatar is a Donnie head.
Rich is offline
post #6 of 8 (permalink) Old 09-02-2001, 02:08 PM
I'm using the D'addario XL110 7 string set and am very pleased.
It's 10-56.
jeffrey is offline
post #7 of 8 (permalink) Old 09-02-2001, 02:12 PM
I used to use 10-52 and a 62 for B on my 7420 and I had 5 springs in the back.:loco:
Right now though, I'm using 9-42 and a 52 for B and 3 springs on both my 7420 and Universe. I just like the feel of 9-42's. As far as a difference in tone, I didn't notice much of a change. Not considering how much nicer they play now.
Alden
YaYoGakk is offline
post #8 of 8 (permalink) Old 09-02-2001, 06:10 PM Thread Starter
I will try the D'addario's. I am getting the guit set-up professionnaly and will install a fourth spring.
Thanx guys.
gauge strings , guitar tech
Just finished project. what you guys/gals think? (PICS) smasher2000 Tech: Setup, Repairs and Mods 8 02-14-2009 03:19 PM
Hi guys/gals, please check my myspace, I've uploaded a new song!! jemburner Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 9 09-13-2007 07:27 AM
Another sale for you DIY guys (gals) Ayrton All Other Guitars (including Prestige) 1 12-02-2006 04:27 AM
What do you guys/gals think the best direct pre-amp is The Dude Gear, Equipment, Recording & Off Topic 29 09-27-2002 12:57 PM
HTML code is On
