Removing the neck finish - Do I have to remove the lo pro ?? - Jemsite
post #1 of 2 (permalink) Old 01-16-2002, 05:48 PM Thread Starter
I am going to remove the sticky finish on the back of the neck according to the instructions in the tech area. I will remove the neck while doing the modification. It says: "Lock the nut and proceed with the instructions with removing the tremolo from "Nut Height Setup"." I may be stupid, but does it mean I have to remove the lo pro? If it does, how ??
-replies will be appreciated
Fredrik
BronzeMan is offline
post #2 of 2 (permalink) Old 01-16-2002, 05:52 PM
site founder 0% owner
jemsite's Avatar
#Moderation Mode
moved to correct area... will reply in a bit
<a href="http://jemsiteforum.com/board/topic.cgi?forum=6&topic=798" target="_self">Moved here</a>
jemsite is offline
Closed Thread
nut height
Removing neck-finish straymond Tech: Setup, Repairs and Mods 8 07-01-2006 02:45 AM
You CAN remove binding w/out removing frets john1880 Tech: Setup, Repairs and Mods 6 08-04-2005 09:56 PM
Remove finish johank Tech: Setup, Repairs and Mods 10 08-16-2002 02:27 PM
If you remove the finish on the neck - doesnīt your sweat ru theblackpage Ibanez JEM, UV, JS & Other Signature Models 4 01-17-2002 06:06 PM
Removing the neck finish - Do I have to remove the lo pro ?? BronzeMan Tech: Setup, Repairs and Mods 4 01-17-2002 04:16 PM
HTML code is On
