Replace Cracked JS100 Neck with Jem neck - Jemsite
post #1 of 16 (permalink) Old 12-21-2006, 07:22 PM Thread Starter
ggl
Thumbs down Replace Cracked JS100 Neck with Jem neck
My JS100 (1994 black model) has a crack in the neck and I got it checked by a luthier who confirmed it is unrepairable so I need to replace it. I thought that placing a Jem Neck in it might be cool but I have read that you can only buy the exact same model neck from Ibanez and you have to send the old one in. I have some pictures of my js100 here of this.
Any thoughts on this would help, what would you do in a situation like this?
ggl is offline
post #2 of 16 (permalink) Old 12-21-2006, 07:26 PM
Re: Replace Cracked JS100 Neck with Jem neck
Bad idea even if you COULD get a Jem neck. Because the Jem neck has 24 frets and the JS has 22, they're different lengths. They're not designed to be interchangable.
Petie is offline
post #3 of 16 (permalink) Old 12-21-2006, 07:27 PM
The crack is confined only to the area near the nut, right? If so, based on those pics it looks like it may be repairable. Check out Rich's tutorial at ibanezrules.com.
giannifive is offline
post #4 of 16 (permalink) Old 12-21-2006, 07:38 PM
yeah you wouldnt be able to do it as intonation would be impossible due to the different scale length , sorry man
jem_fanatic is offline
post #5 of 16 (permalink) Old 12-21-2006, 07:50 PM
based on the pics very much repairable with actually not very much effort and evven less tools
dragsternj is offline
post #6 of 16 (permalink) Old 12-21-2006, 09:24 PM
The neck may have different overall lengths, due the the total number of frets, but they are the exact same scale length (25.5").
toneboy is offline
post #7 of 16 (permalink) Old 12-21-2006, 10:06 PM
yup, you wouldn't have any tuning issues or intonation issues it's the fact that it has 24 frets vs 22. If you tried to put the Jem neck on the JS guitar the last 2 frets would run into the neck pickup. So to get it to fit you'd need to route a bigger neck pickup cavity to place the neck pickup towards the bridge more.
Also, the Jem neck has a AAJN and the bolt setup are completely different so to get it to fit you'd need to modify the body or modify the neck. IMO not worth it, buy an RG if you want that style or just buy a new JS100 or upgrade yourself to a JS1000.
RSVampire is offline
post #8 of 16 (permalink) Old 12-22-2006, 12:58 AM Thread Starter
ggl
ok the feedback/ideas has been welcome from everyone....
It does extend up towards the tuners slightly as you can see in the pics although the length of the split is not highlighted so well in the pictures. It's also split in three places (by the middle of the holes, top & below each hole)
I checked out that great tutorial on a split neck repair and it looks like I may be able to do this, it's worth a shot at least....
I have one question with repairing this, Would I have much problems putting the neck back on the the body again? I guess I will have to get the truss rod all set up correct plus all the intonation setup can get tricky....
With the Jem neck question, well I will have to forget that, it was just an idea.
My plan now after thinking about it is to try to fix it first and if that doesn't work too well then I will try to see if I can get hold of a neck on eb or maybe try to sell it this like it is as "needing repair" - I would most likely take out the dimarzios for my next guitar though...
ggl is offline
post #9 of 16 (permalink) Old 12-22-2006, 01:11 AM
Ouch, what happened?
LethalAe86TypeR is offline
post #10 of 16 (permalink) Old 12-22-2006, 01:24 AM Thread Starter
ggl
I'm not even sure, I do remember bumping it against a wall a few months ago so maybe it was that but I never noticed it until recently (about 3 weeks ago). Maybe it was just from the changing weather patterns here in Aussie?
I have been reading some other threads like this one here, it seems some people replace this neck if they want to improve it so maybe looking at another neck like the one used in the js1000 or an aanj neck ( I have no idea what this is yet) could be an option if the repair job doesn't work.
ggl is offline
post #11 of 16 (permalink) Old 12-22-2006, 01:46 AM
AANJ= All Access Neck Joint
post #12 of 16 (permalink) Old 12-22-2006, 08:13 AM
jb4674's Avatar
Reviews: 18
It really is too bad you can't just buy a neck from Ibanez direct without having to send the core.
Jimmy
jb4674 is offline
post #13 of 16 (permalink) Old 12-22-2006, 08:13 AM
Taking it off an putting back on should not be a problem at all, intonation should not change and you may not even have to touch the truss rod.
post #14 of 16 (permalink) Old 12-22-2006, 09:53 AM Thread Starter
ggl
ok I see now
yeah, I think they cost a fair bit as well but I guess sending the neck in is not a big deal and I would not need it again or do you mean I have to send the rest of the guitar in as well to verify I need one? ... at a guess maybe it would cost about $400 US plus shipping costs from australia to US could be another $100? if I was gonna buy a new one or replace the neck and spend any sort of cash like that then I would prefer to get a js1000 neck and what they cost is anyone's guess? If I did that and replaced the trem I would nearly have something as good as a js1000 since it has dimarzio's in it already and similiar wiring to the 1000. As for buying necks then I think using eb would be the best idea in this situation.
that's good to hear then, I will go shopping next week and find some suitable glue etc and get started and will be sure to update this thread on how it goes....
ggl is offline
post #15 of 16 (permalink) Old 12-22-2006, 12:18 PM
I have a JS1000 neck off a new guitar where the nut screw broke off in it. I've Dremmeled it mostly out but it still needs a little attention, in fact I'd have it thru drilled for a regular nut. In case you need.
Rich is offline
aanj neck , access neck joint , jem neck , neck joint , neck pickup , pickup cavity , truss rod
Jem Neck on Regular RG Body accident? Societysucks Ibanez JEM, UV, JS & Other Signature Models 10 12-08-2004 06:18 PM
Jem 7VWH neck question blackfuneral Ibanez JEM, UV, JS & Other Signature Models 5 07-10-2003 10:20 PM
Broken Jem 7D Neck - Help! Fripp Logic Ibanez JEM, UV, JS & Other Signature Models 2 06-17-2003 04:22 PM
to replace JEM neck where to get a new one? Jare Ibanez JEM, UV, JS & Other Signature Models 5 05-15-2003 01:18 PM
Replace neck nicko All Other Guitars (including Prestige) 2 03-02-2003 09:07 PM
HTML code is On
