Replacement Volume, Tone and 3-way Switch for a JS2400 - Jemsite
post #1 of 4 (permalink) Old 09-05-2014, 05:02 PM Thread Starter
Spilled soda liquid on the guitar ( accident of course) and now the volume, tone and switch don't work properly (scratchy, sticky).
So am looking to get new ones and wondering what they are - I do want the high-pass filter back and the coil-tap as well.
The one's I saw were on Rich's site www.ibanezrules.com (picture attached and marked with a red rectangle) but unsure if they are the same. Can someone help?
1. Do I need the same pots for volume and tone?
2. Is that 3-way switch the right one?
I'm handy with capacitors, electronics and a soldering iron so can put it together - just need the right ones first.
Thanks in advance.
xperiate is offline
post #2 of 4 (permalink) Old 09-05-2014, 05:07 PM
Re: Replacement Volume, Tone and 3-way Switch for a JS2400
Unbolt everything until you can pull it away from the body enough to let it soak in a glass/bowl of water. Spin the pots, flip the switch. It's only sugar, it'll dissolve. Blow them out good with compressed air, and then let sit for a day before you put any signal thru them.
Rich is offline
post #3 of 4 (permalink) Old 09-05-2014, 05:48 PM Thread Starter
I'll give that a shot and report back. But if I was to buy replacements, should I be getting the ones I highlighted above?
xperiate is offline
post #4 of 4 (permalink) Old 09-06-2014, 03:23 PM
A contact cleaner might also help as well...
jazzedout is offline
js2400 , js2410
FS: Seymour Duncan Blackout Set - Bridge and Neck, 3 way switch, volume/tone/battery avicenna777 Classified Ads: Guitars and Gear 0 07-04-2010 12:58 PM
Looking for green volume/tone knobs and switch tip Andy Mclaughlan Tech: Setup, Repairs and Mods 2 04-28-2009 11:21 AM
Volume/Tone pot replacement heffergm Tech: Setup, Repairs and Mods 2 03-20-2008 01:52 AM
FS: Yellow Volume,Tone Knobs & Switch Tip djpharoah Classified Ads: Guitars and Gear 4 05-13-2007 02:04 PM
Jem volume pot replacement question HSH Tech: Setup, Repairs and Mods 3 08-10-2006 08:45 PM
HTML code is On
