Routing help - Jemsite
post #1 of 4 (permalink) Old 03-06-2005, 02:00 AM Thread Starter
Routing help
Hey, im having trouble on how to route the hole to send the wires through the jack to control cavity. Any ideas?
Andy43 is offline
post #2 of 4 (permalink) Old 03-06-2005, 02:29 AM
Re: Routing help
yeah, use a long drill bit (often called a gun drill) that is like 12" in length and drill it, it only needs to be 3/16" for the 2 wires to pass through, they're drilled in at a shallow angle.
littlegreenman is offline
post #3 of 4 (permalink) Old 03-06-2005, 12:09 PM Thread Starter
Re: Routing help
Do you have to use a small drill?
Andy43 is offline
post #4 of 4 (permalink) Old 03-06-2005, 01:18 PM
Re: Routing help
That's how I did it, routed out a middle pickup cavity that didn't exist then drilled
a straight line w/ 3/16" from the 'corner' closets to the control cav. Worked out
fine.
RapIsNotMusic is offline
pickup cavity
Jem routing Vince~ Tech: Setup, Repairs and Mods 8 09-12-2006 07:19 AM
Lo-Pro Universe routing RapIsNotMusic Tech: Setup, Repairs and Mods 8 01-25-2005 04:56 PM
routing questions. nocluejimbo All Other Guitars (including Prestige) 2 10-20-2004 10:00 PM
Routing UV? metalmarty Ibanez JEM, UV, JS & Other Signature Models 34 11-28-2002 01:17 PM
2-1-1 v. 2-1-2 routing gkelm Tech: Setup, Repairs and Mods 1 03-29-2001 06:59 AM
HTML code is On
