Routing UV? - Jemsite
post #1 of 35 (permalink) Old 11-25-2002, 01:18 PM Thread Starter
Routing UV?
I'm still waiting for my UV777BK (ordered it end of August, expected to arrive end of January ) and I'm really thinking of putting in EMG 707's. I know the PU-cavaties will have to be routed, but I was wondering how that is done considering the finish. Won't that crack arond the edges? Does anybody have pics of the body before and after the routing? I'm just a little worried about putting a saw to my new $1900 guitar
metalmarty is offline
post #2 of 35 (permalink) Old 11-25-2002, 01:41 PM
EKG
It may chip the finish along the edges of the routing, yes. The pickguard should cover up any flaws that may occur. If you take your time, go about it nice and slow, you should be fine ;-)
I would try on a "practice" body first.
EKG is offline
post #3 of 35 (permalink) Old 11-25-2002, 01:58 PM
use a NEW router bit (a sharp one) and cover the entire area the router base will touch with masking tape, draw your route pattern on the tape, and route it all with the tape on, when you peel the tape off, pull it back on itself very close to the body TOWARDS the edge you just routed, you probably won't end up with any chips in the finish, but more importantly, you won't end up scratching your body up.
littlegreenman is offline
post #4 of 35 (permalink) Old 11-25-2002, 02:05 PM
EKG
Good point, Jeremy....the tape thing for no cracking.
I do the same thing, but I didn't think of it at the time I posted
Also, I use templates and mask the body with this blue film I have, basically the same thing as tape ;-)
EKG is offline
post #5 of 35 (permalink) Old 11-25-2002, 02:19 PM
Tape is a great idea.FOr hardwood floors,I use blue painters tape since the extra adhesive strength of masking tape can cause problems.The green painters tape is even better.It is less likely to stick to any potentially loose pieces of finish on your guitar afte you route it pull them off.Unless you are having someone else do it for you .
Paul Secondino is offline
post #6 of 35 (permalink) Old 11-25-2002, 02:21 PM
I just noticed that my grammar was horrible in that post.I am not even sure if I spelled Grammar correctly.
post #7 of 35 (permalink) Old 11-25-2002, 02:38 PM
Your s p a c e bar isn't working either
Rich is offline
post #8 of 35 (permalink) Old 11-25-2002, 02:50 PM
Would it also help to lightly trace the outline of the area to be routed with an X-acto knife and a sharp, fresh blade? That might help prevent any chipping, etc. as well I'd think.
vaijem777 is offline
post #9 of 35 (permalink) Old 11-25-2002, 04:04 PM
EKG
I believe that would help.
EKG is offline
post #10 of 35 (permalink) Old 11-25-2002, 05:05 PM
if you actually had the patience to cut through the clear with it, Exacto's are good, but man, that clear is tougher than you think. if you have a very sharp router blade though, you can do it. I've cut monkey grips in finished bodies with no chipping, then all you have to do is refinish the grip.
post #11 of 35 (permalink) Old 11-25-2002, 05:13 PM
EKG
Should this be in the Tech: Setup, Repair & Mods section?
You use a Router for the grip?
EKG is offline
post #12 of 35 (permalink) Old 11-25-2002, 05:41 PM
ya, what do you use? LOL
post #13 of 35 (permalink) Old 11-25-2002, 05:46 PM
EKG
Hee hee hee, now, now, I can't reveal my trade secrets ;-)
EKG is offline
post #14 of 35 (permalink) Old 11-25-2002, 06:17 PM
Brian's tutorial on projectguitar shows it being done with a spade bit (or a hole saw bit) and a jigsaw.
darren wilson is offline
post #15 of 35 (permalink) Old 11-25-2002, 06:32 PM
yup, but a router is sooooooooooo much easier and does nicer work
monkey grip
Jem routing Vince~ Tech: Setup, Repairs and Mods 8 09-12-2006 07:19 AM
Routing help Andy43 Ibanez JEM, UV, JS & Other Signature Models 3 03-06-2005 01:18 PM
Lo-Pro Universe routing RapIsNotMusic Tech: Setup, Repairs and Mods 8 01-25-2005 04:56 PM
routing questions. nocluejimbo All Other Guitars (including Prestige) 2 10-20-2004 10:00 PM
2-1-1 v. 2-1-2 routing gkelm Tech: Setup, Repairs and Mods 1 03-29-2001 06:59 AM
HTML code is On
