Side dots on Jem7vwh - Jemsite
post #1 of 16 (permalink) Old 06-01-2002, 10:08 PM Thread Starter
I did a search, but I didn't come up with anything, but if this topis has been previously discussed, plesae let me know.
Are the side dots on a 7vwh, as well as all other Jems actual inlay or are they painted dots? I'm getting ready to strip the finish off the neck of my 7vwh and I want to be sure. If they're inlays, then there's nothing to worry about. If they're painted, then i may have a problem.
Thanx,
Peter
lhrocker is offline
post #2 of 16 (permalink) Old 06-01-2002, 10:17 PM
site founder 0% owner
jemsite's Avatar
i don't have an axe handy to double check, but it doesn't matter... when stripping the neck finish, there is no reason to touch the side markers... concentrate on the maple neck ...glen
jemsite is offline
post #3 of 16 (permalink) Old 06-03-2002, 08:30 PM
Post subject: Side dots on Jem7vwh
I just checked my 7vwh and the side dots are inlays. I can tell because the one for the fifth fret you can feel the edge of it with your fingernail I guess they did not sand that one good enough on mine.
wireman24 is offline
post #4 of 16 (permalink) Old 06-04-2002, 05:18 PM
I looked at mine with a magnifying glass, definately painted. It's an '01.
Triangle is offline
post #5 of 16 (permalink) Old 06-04-2002, 09:18 PM
I just checked an 01', definately white plastic. I've never seen a Jem with painted markers.
Rich is offline
post #6 of 16 (permalink) Old 06-04-2002, 09:19 PM
They are all inlays, doing side dot inlays is so easy, drill a 1/16" or 3/32" hole, drop in the length of rod, cut it flush, sand it, boom done. Paint wouldn't last for **** on the side, I guarantee they are all inlaid.
littlegreenman is offline
post #7 of 16 (permalink) Old 06-05-2002, 06:47 AM
This is something that I raised a few months ago when I posted re stripping the neck on my Vwh. I never did it in the end because I was worried about removing the dots with the finish.
Mine definitely look like they have been painted on and not inlaid. It looks like the laquer on the back of the neck has continued over the edge of the fingerboard to protect the dots from rubbing off. The grain of the wood can actually be seen through the dots where the white paint has sunk in. They definiety, absolutely, positively, 100% not inlays on my guitar!
It's '96 Vwh btw.
wallopwallop is offline
post #8 of 16 (permalink) Old 06-05-2002, 07:31 AM
wallopwallop Posted: Wed Jun 05, 2002 12:47 pm Post subject:
Same thing on my UV7 PWH ('90). I can't say if it's paint or something else, but not inlays... Furthermore, as there's no laquer on the neck, it's not very good looking anymore - But I'm still in love !
eddie 42 is offline
post #9 of 16 (permalink) Old 06-05-2002, 09:15 AM
You're probably seeing the sanding lines still visible in the plastic.
Rich is offline
post #10 of 16 (permalink) Old 06-05-2002, 09:54 AM
If they were sanding lines then Ibanez Quality Control has gone right out of the window! They are simply too deep and follow individual grains and inpressions in the wood perfectly.
I wish I had a digital camera!!!
post #11 of 16 (permalink) Old 06-05-2002, 12:03 PM
They're inlays, look at them again, and again, till you can see the slight distrubance of the wood at the sides of the inlays from the drill.
Rich is offline
post #12 of 16 (permalink) Old 06-05-2002, 12:20 PM
My magnifying glass is in my bag ready to have a closer inspection when I get home tonight. I'll let you know what I find. If they are inlays then the neck is getting stripped pronto!
BTW. I'm not trying to be argumentative here . The dots just dont look like plastic inlays I have ever seen on any guitar. As I said, they follow the grain of the wood perfectly.
Thanks for the advice.
Matt
post #13 of 16 (permalink) Old 06-05-2002, 05:21 PM
Checked.... (my last post was written from the office), and yes, Mr Rich is once again right : inlays they are.... (on the PWH). I'll write a 100 times : I shall not contradict Rich Harris when talking about Jems / UVs, I shall not contradict Rich Harris when talking about Jems / UVs, I shall not contradict Rich Harris when talking about Jems / UVs,.... (OK, I admit it was copied / pasted ).
But yes, I only could say that they were actually inlays after taking a close look, and the general impression (that they were not inlays) I had after 1.5 year of ownership was sincere. I think it is due to the fact that those dots yellowished a lot (maybe a lack of UV protection (I mean UltraViolet, not Universe ) in the raw material used for those plastic inlays, and also to the fact that some of them are scratched with (sanding ?) lines that strangely follow the grain of the wood, giving the impression of a cracks in a paint coating.
Anyway, I shall not contradict Rich Harris when talking about Jems / UVs, I shall not contradict Rich Harris when talking about Jems / UVs, I shall not contradict Rich Harris when talking about Jems / UVs,....
eddie 42 is offline
post #14 of 16 (permalink) Old 06-05-2002, 08:18 PM
The reason the sanding lines in the plastic follow the "grain" lines, is they are probably not actually grain lines, but lines in the wood also from sanding. All that says is that they did not polish out the sanding scratches that well. But, as I said too, they are inlays, it would be faster to do inlays like that than to paint them on. Simple as that!
post #15 of 16 (permalink) Old 06-06-2002, 03:34 AM
Feel free to contradict me whenever you want!! There's only one thing I'm 100% sure of, and that's that I'll never be 100% right!
Rich is offline
dot inlay , dot inlays , maple neck , neck finish
UV Green dots - UV Silver dots : same neck ? Agent540 Ibanez JEM, UV, JS & Other Signature Models 4 10-06-2012 04:27 PM
Bass side trem post lower than treble side - good to go? Tannen Tech: Setup, Repairs and Mods 1 09-17-2011 11:45 AM
Fret dots ninjasuz Tech: Setup, Repairs and Mods 2 05-19-2008 11:12 AM
neck keeps moving side to side brothersnowgone Tech: Setup, Repairs and Mods 6 08-07-2006 04:22 AM
Small side dots on any other Jem other than DBK lhrocker Ibanez JEM, UV, JS & Other Signature Models 17 07-04-2002 08:34 AM
HTML code is On
