Slight G-string buzz after tightening the pressure pad - Jemsite
post #1 of 26 (permalink) Old 07-20-2010, 11:05 AM Thread Starter
Hi guys,
I recently bought a used 7VSBL and thanks to Rich's instructions in his web site, I am close to setting it up perfectly for me (about 0.25 mm relief at 9th with 2mm action low-E side and about 1.8mm on the high-E, with a perfect trem angle).
Anyways, one small problem remains after all the tweaks. When I tighten the pressure pad on the D-G strings there is a slight buzz coming from the clean G string (no buzz when the pad is removed or at any other frets). I found that this situation can be remedied by tightening the pressure pad rotated 90 degrees. It is interesting that changing the position of the pads did not do any good, so I am pretty sure it is not the pad that is the problem.
Is tightening the pad this way going to have an adverse effect on the NUT in the long term? What do you think the root of the problem might be?
Thanks,
Sean.
SeanC is offline
post #2 of 26 (permalink) Old 07-20-2010, 11:18 AM
Reviews: 4
Re: Slight G-string buzz after tightening the pressure pad
There is something kinda wrong about the title of this thread :-p .
Not sure about the cause, but you seem to be moving in the right direction.
Hey, SeanC, any relation to Sean Carpenter???
fwd0120 is offline
post #3 of 26 (permalink) Old 07-20-2010, 12:00 PM Thread Starter
lol haven't noticed until you pointed out And no, no relations to any Sean Carpenters.
SeanC is offline
post #4 of 26 (permalink) Old 07-20-2010, 12:17 PM
1)Chance out pressure pads and see if it makes a difference.
2)Check if your lockingnut is fastend correctly with the screws on the back of the neck.
3)Adjust the stringtree so the string will follow the whole curve of the lockingnut.
Good luck!
Death.by.G-string is offline
post #5 of 26 (permalink) Old 07-20-2010, 12:25 PM Thread Starter
Good luck!
Already tried (1) and it didn't make any difference. Locking nut is fastened correctly as well.
Haven't thought about adjusting the stringtree though. I will try it tonight. Thanks!
SeanC is offline
post #6 of 26 (permalink) Old 07-21-2010, 03:04 PM Thread Starter
Ok, adjusting the stringtree didn't help as well. I am open to other suggestions.
(I feel like getting a new nut and pressure pads will solve the problem completely, but don't want to go that route unless absolutely necessary. Or I will just keep tightening the pressure pad rotated 90 degrees)...
SeanC is offline
post #7 of 26 (permalink) Old 07-21-2010, 03:10 PM
Take a pick and press down on the string at the edge of the nut and check then.
Rich is offline
post #8 of 26 (permalink) Old 07-21-2010, 09:26 PM Thread Starter
Thanks Rich, I still get a slight buzz after doing what you suggested, but I think this is because I cannot press down hard enough with the pick with one hand while picking with the other.
The only solution that has worked for me so far is simply tightening the pressure pad rotated 90 degrees. Is this something that I should refrain from doing?
SeanC is offline
post #9 of 26 (permalink) Old 07-22-2010, 12:13 AM
Reviews: 11
It doesn't lock the strings if you rotate it 90 degrees. Take a look at the pad's bottom.. It's a bit curved, so it matches perfectly with the locking nuts shape..
FrostStorm is offline
post #10 of 26 (permalink) Old 07-22-2010, 12:47 AM
Loosen the truss rod to rule out first fret buzz.
Rich is offline
post #11 of 26 (permalink) Old 07-22-2010, 09:53 AM Thread Starter
I am aware of the slight curve underneath the pad to mate perfectly with the NUT, but the guitar stays in perfect tune even when the pad is installed as described.
To check, I loosed the tuners with the pad installed as it is (rotated), dive bombed a few times, and it still comes back to tune %100.
Maybe I misunderstood your previous post, but there is no first fret buzz (or any other fret buzz for that matter) at all. The buzz is there only when the pad is installed the correct way and when the G-string played empty.
SeanC is offline
post #12 of 26 (permalink) Old 07-22-2010, 11:31 AM
In that case)
Are the bolts of the pads all original?
Could be there to long and hit the neckwood so they don't fasten enough.
No dents on the pads or on the nut ,or wornout screwholes,bolts??
If not,.... i think u need to replace the nut.
post #13 of 26 (permalink) Old 07-22-2010, 11:40 AM Thread Starter
In that case)
All bolts are original. No dents on the nut, screw holes and bolts seem to be in good condition, however there are "grooves" underneath the pads that I believe were caused by the strings over time or due to over-tightening of the pads by the previous owner.
So I guess I will change out the strings first, if that doesn't do it, I will order a new pad from Rich, and finally a nut if that doesn't do it either.
SeanC is offline
post #14 of 26 (permalink) Old 07-22-2010, 08:38 PM
Reviews: 12
Red face Re: Slight G-string buzz after tightening the pressure pad
1-Truss your rod
2-Replace your nuts
3-press her pad
4-take the G-string off
5-Get a good buzz going on
6-Play with her all night long
Oh wait, you meant guitar stuff? My bad!
DEADTUNES666 is offline
post #15 of 26 (permalink) Old 07-22-2010, 10:02 PM Thread Starter
lol well played!
SeanC is offline
buzz , nut , pressure pad
String buzz Sportrider24 Tech: Setup, Repairs and Mods 14 11-02-2010 02:38 PM
note sounds :dead: Slight buzz only on the Low E string "C" note nighttraveler Tech: Setup, Repairs and Mods 1 06-11-2009 11:10 PM
Need help with string buzz RG_76 Tech: Setup, Repairs and Mods 2 04-17-2005 03:09 PM
WTB : UNIVERSE neck Pressure pads and Pressure pad bolts JEAPSON Classified Ads: Ibanez JEM/UV Guitars 2 12-04-2004 06:46 PM
String Buzz Reishiman Tech: Setup, Repairs and Mods 10 02-12-2004 04:28 PM
HTML code is On
