So here's my Problem: - I snap strings at the bridge everyda - Jemsite
post #1 of 16 (permalink) Old 03-28-2002, 10:39 AM Thread Starter
Yup. *Never fails. *Always right at the bridge. *
Why the heck does this happen? *Anyone got any advice?
davester1234 is offline
post #2 of 16 (permalink) Old 03-28-2002, 11:43 AM
Think of the physics of it. *A string will break for one of two reasons:
The first is that there's too much pressure pulling it length-wise. *This is more common with over-tightening or making the high E a high B.
The second is that there is a force acting upon the string and causing a weakness. *This sort of thing is usually found in one general location, like the bridge. *Since it's happening fairly often then I'm assuming that there's something non-standard acting upon the string at the bridge and causing a break.
Check the saddle for any sharp points. *A burr in it can cause this and my best bet would be as such. *If you find the burr or sharpeed area the obvious answer is to smooth it over in some way. *A small metal file would be advised. *A Dremel with the right attatchment could make short work of it but I'd be reluctant to go so potentially overboard so quickly. *Your other option would be to replace the saddle entirely. *I'd only suggest this as a last ditch effort.
Skarekrough is offline
post #3 of 16 (permalink) Old 03-28-2002, 11:51 AM
There's a third common cause for breaking string and that's too hard and steep a pick attack. [the only time I ever break a string is when I get too sloppy and heavy with my right hand] The last way, metal fatigue, I'd consider isn't the problem if you're changing the string everyday.
Rich is offline
post #4 of 16 (permalink) Old 03-28-2002, 01:01 PM
What bridge do you have?Are you using a metal pick?How often do you change strings?All my guitars have lo-pros.I have encountered the burr in the saddle problem(7vwh).After gently filing the offending saddle(low e),no more problems.The only time I break a string is when I get lazy and don't change them regularly.A freind uses a metal pick and regularly blows out the low strings,though he is pretty heavy handed.
musicdr is offline
post #5 of 16 (permalink) Old 03-28-2002, 01:06 PM Thread Starter
I'm playing a 777vbk, obviously with a lopro edge trem.
I guess I don't break strings every everyday, but a couple of times a week....different strings, but always right at the saddle.
post #6 of 16 (permalink) Old 03-28-2002, 04:04 PM
Wow dude,you must be a playing maniac to break them that regular.
musicdr is offline
post #7 of 16 (permalink) Old 03-28-2002, 05:38 PM Thread Starter
no man, not at all. *okay, I'm very Vai'ish, in that I use the bar alot. *But its still no excuse for breakage on every string at the same area. *I can't remember the last time I broke a string away from the saddle.
post #8 of 16 (permalink) Old 03-28-2002, 05:40 PM
Is the trem angle correct? If it's not it puts extra stress at the bend of the string at the saddle.
Rich is offline
post #9 of 16 (permalink) Old 03-28-2002, 06:49 PM Thread Starter
hmmmmmmm..........
post #10 of 16 (permalink) Old 03-28-2002, 08:07 PM
Excellent point Rich.
musicdr is offline
post #11 of 16 (permalink) Old 04-04-2002, 07:01 PM
This is more than likely irrelevant, but I'll divulge regardless. *I too had problems when I first got my 7vwh. *I was using Daddario .10's at the time, and was snapping strings once a week. *I was jamming with a buddy who just finished up at GIT, and he suggested that I try his newest discovery: ghs boomers. *I switched, and haven't snapped a string in ages. *This probably doesn't relate in your situation, but who knows? *
PiratesJem is offline
post #12 of 16 (permalink) Old 04-05-2002, 12:02 AM
I dont know, but Boomers do kick * *I use em and rarely break strings. *On the other hand, I used a set of Ernie Balls once a few months back and broke 2 within 3 weeks....
Rich does have a good point though, check the trem angle. *Too much of a downward angle puts mega stress on the strings.
Guitarlos2 is offline
post #13 of 16 (permalink) Old 04-05-2002, 12:58 AM Thread Starter
well, the bridge sits above guitar level, just like in the pix showing the way its supposed to be on the site. *I'm thinking there's some crud in the saddles. *2 strings in 3 weeks?? bwaahahahaha!!! *That would be an accomplishment worth documenting for me. *:biggrin:
Pardon my ignorance, but what are boomers?
(seems like every topic that comes up, I'm the guy askin whats this mean, whats that mean!! Sorry folks!)
post #14 of 16 (permalink) Old 04-05-2002, 01:15 AM
GHS Boomers, just a different brand of nickel wound guitar strings. *Everyone has a different preference when it comes to strings, but Ive been happy using these for years. *They sound bright and full, and seem more resistant to breakage.
post #15 of 16 (permalink) Old 04-05-2002, 02:52 AM
I've been using DR's,can't remember last time I broke a string.Probably when I had the burr in the saddle problem.
musicdr is offline
edge trem , ernie ball , ernie balls , low strings , pro edge , pro edge trem
Strings problem sebotas86 Tech: Setup, Repairs and Mods 1 12-11-2009 05:50 PM
Strings keep going flat with ZR bridge Joshu Tech: Setup, Repairs and Mods 0 03-08-2009 06:31 PM
Fret Buzz problem, lower 3 strings only. SidewinderINC Tech: Setup, Repairs and Mods 6 04-02-2006 03:12 PM
How often do you snap strings? weserman Tech: Setup, Repairs and Mods 25 04-02-2003 01:31 AM
Snap, Snap, Snap! - Think I need a longer screw. Two hands31 Gear, Equipment, Recording & Off Topic 0 01-09-2002 06:31 PM
HTML code is On
