Sounds like a daft question but... why veneer a 3 piece body - showing my ignorance ! - Jemsite
post #1 of 15 (permalink) Old 09-24-2007, 04:42 PM Thread Starter
Jaden's Avatar
I just modded a RG7420 (description from the neck pocket) body for a forum member and learned something new...
when the body was sanded down it was clear that it was of 3 piece construction - the face of the guitar was clearly different....
it looked (on the face of it) to be a one piece body....
this guitar was painted originally, is the veneer to hide movement between the 3 pieces of basswood that make the body from showing in the paint ?
I know a lot of you guys are very knowledgeable about this stuff.......
why veneer a guitar thats going to be painted.? perhaps to hide those two "fault" lines that appeared in early ibanez guitars where the jointing was visible ?
Jaden is offline
post #2 of 15 (permalink) Old 09-24-2007, 04:58 PM
Dee
Re: Sounds like a daft question but... why veneer a 3 piece body - showing my ignorance !
Did you know that the JEM VWH has a basswood veneer? It stops the paint sinking into the alder. I wouldn't be surprised to see the same kind of thing on other Ibanez guitars.
Dee is offline
post #3 of 15 (permalink) Old 09-24-2007, 05:02 PM Thread Starter
Jaden's Avatar
I didnt know that, but thats what I meant by the "fault" lines - I have an early ibanez where the jointing is clearly visible through the paint....
that seems to be the case here - its a year 2000 7 string... with a basswood veneer.
Jaden is offline
post #4 of 15 (permalink) Old 09-24-2007, 05:17 PM
Dee
Yep, I have had 3 RG's with visible lines, including my new RG20th which has one visible line. You really have to look very close to see it, but it's there. The veneer is a good idea.
Dee is offline
post #5 of 15 (permalink) Old 09-25-2007, 08:13 AM
The wood construction lines are on alot of my ibanez guitars incluing a PGM and a 7 string none the less, you have to look really hard to the light to see them though; someone posted pics of a JEM7DBK ages ago and the body was in six pieces apparently, Tom.
Necrojem is offline
post #6 of 15 (permalink) Old 09-25-2007, 11:22 AM
jim777's Avatar
I don't believe Ibanez would add an extra piece to a non-endorsee guitar to hide a seam. For a regular RG series guitar it's possible they might add a veneer to a guitar top if the other two pieces weren't thick enough, though. Pieces are usually added to get the guitar to the proper size spec, and no other reason. I think we've all seen or heard of guitars that were as many as 8 or 9 pieces. The 7VWH has the basswood veneer due to the paint, and no other reason.
jim777 is offline
post #7 of 15 (permalink) Old 09-25-2007, 02:19 PM
I'm sure some-else started this thread
andy7jem is offline
post #8 of 15 (permalink) Old 09-25-2007, 02:21 PM
AirGuitar's Avatar
My RG1527 had a very clear line down the middle, nothing at all on my Jem or my RG570 though.
AirGuitar is offline
post #9 of 15 (permalink) Old 09-25-2007, 02:41 PM
I've stripped a few Ibanez bodies over the last couple of years and all of them had a front and back veneer - I guess they do it so they can be less fussy over the main pieces of wood that make up the body, but that's just an assumption.
Serratus is offline
post #10 of 15 (permalink) Old 09-25-2007, 04:08 PM Thread Starter
Jaden's Avatar
Rich, I assumed the same thing really - not a lot of other reasons to veneer a body other than hiding bad wood....
I didnt strip the wood on this one as I would rather make a new body from scratch than strip and sand
also, nice to see you still around Rich
Jaden is offline
post #11 of 15 (permalink) Old 09-25-2007, 04:12 PM Thread Starter
Jaden's Avatar
hmmm... yes, thanks to Glen for changing my username.....
simply got fed up with a "username" and like to be a "real name"
hence - Jaden
Jaden is offline
post #12 of 15 (permalink) Old 09-26-2007, 02:05 AM
My 7vwh has visible lines too :s
Kerem is offline
post #13 of 15 (permalink) Old 09-26-2007, 02:14 AM
Purely guessing here, but maybe the Basswood core has some kind of flaw in it (a knot perhaps?) which would sink badly, hence a veneer to cover this - instinct tells me that it would be cheaper for Ibanez to simply junk such a body and move on to the next one, rather than going to the trouble of a veneer, so really I don't have a clue why they'd do this....
David McCarroll is offline
post #14 of 15 (permalink) Old 09-26-2007, 02:39 AM
My '87 RG550 has a very severe line on the bass side.
Petie is offline
post #15 of 15 (permalink) Old 09-26-2007, 05:19 AM
i've seen many Ibanez guitars now and all of them had 3 lines. i like it cause it seems like the wood's dried out and moved thru the years. never saw lines in guitars younger than 6 to 8 y.o.
nuno is offline
ibanez guitars , jem vwh
Damaged body question DrAteriusBlank Tech: Setup, Repairs and Mods 2 03-07-2007 12:26 PM
Question about sealing my guitar body... bcgvh Tech: Setup, Repairs and Mods 1 07-12-2003 02:17 PM
HTML code is On
