Spec's for string block stoppers for Edge Pro - Jemsite
post #1 of 1 (permalink) Old 06-27-2014, 11:11 AM Thread Starter
Hello all.
I play a JS1000. One of the string block stoppers on the guitar is so worn that the allen wrench more or less just spins in the socket, rendering the guitar useless.
Here's the serial number for my guitar - F0337096
I put that in to the guitar dater and this was the result (had to remove link).
I had a look and it seems the trem's fitted to JS1000's in 2003 was the Edge Pro Tremelo. We've been feverishly trying to figure out which stoppers will be compatible with the Edge Pro bridge, as the stoppers for the Edge Pro have been discontinued, here's the page - (had to remove link)
Will the stoppers for the Lo Pro fit properly in the Edge Pro and/or do you know of any generic ones built by Edge Pro spec's at all please?
On the same page, the results for trem' stoppers is this -
Trem Stopper Edge Pro - DISCONTINU
2EL1J-STOP 2EL1J-STOP J-STOP 2EL1J-STOP
Thanks in advice for any advance forthcoming.
Mahatma Coat is offline
edge pro , js1000 , string block stoppers
Edge Pro trem stoppers (5 available) lynchfan6 Classified Ads: Guitars and Gear 3 09-07-2013 02:58 PM
FT: Floyd Rose Brass Trem Block for Ibanez Edge Block t1r12003 Classified Ads: Guitars and Gear 0 02-27-2009 08:19 PM
Edge III Problem (String Block Screws) magic_golem Tech: Setup, Repairs and Mods 1 03-06-2008 09:02 AM
For Trade: 31mm Edge spring block for 41mm block mtxsho93 Classified Ads: Guitars and Gear 0 04-02-2007 05:29 PM
String lock block for Edge trem satchman Tech: Setup, Repairs and Mods 1 07-11-2006 12:38 AM
HTML code is On
