String Buzz - problems with low-action setup on JS1000 - Jemsite
post #1 of 5 (permalink) Old 03-18-2001, 11:08 PM Thread Starter
I got my JS1000 about a month ago and I LOVE IT! *But, I want as low an action as I can get, which shouldn't be a prob with Joe's model. *I had it setup and the guy got the action really low but there was still a little buzz. *No matter what I do, I can't get rid of all the buzz, especially on 12th and up and ESCPECIALLY on G string. *I have never really worried about set up before, so am I being ridiculous by wanting ABSOLUTELY NOT A SINGLE BUZZ on any fret or is that the way it should be?
tadd251 is offline
post #2 of 5 (permalink) Old 03-18-2001, 11:38 PM
String Buzz
Figuring the guy that set it up really knows what he is doing, the neck may need a hint of relief if it does not already have it, or you may need to have the frets leveled. *The latter is more likely if you want NO buzz. *Also, remember that Joe's frets are all re-radiused and leveled with a different fret. *In order to get no buzz, you have to have the right technique and the right setup.
Josh Blagg is offline
post #3 of 5 (permalink) Old 03-18-2001, 11:42 PM
String Buzz
You should probably read through this thread first
http://jemsiteforum.com/board/topic....rum=14&topic=5
Can you make a *clean* 3 step bend on the high E between the 12th and 20th? If so, your action is probably too low on the bass side. Have you checked for a high fret? 1 fret in the higher registers on the G string will be almost dead, very buzzy and all the tone choked out of it if you have a high fret. I'm figuring your action is just set too low. I'd take it back to who set it up and tell him what your problem is.
Rich is offline
post #4 of 5 (permalink) Old 03-19-2001, 02:39 AM Thread Starter
String Buzz
Thanks guys. *I took a good look and the 22nd fret is quite high. *I think I'll wait a while though and let the guitar get broken in before I go planing down any frets. *RICH, you said something about a three step bend? *You mean 3 half steps? *After my initial set up I could not bend more than a whole step on the high e string above the 12th without the last fret totally stopping the tone. *Are you saying that this is supposed to happen?
tadd251 is offline
post #5 of 5 (permalink) Old 03-19-2001, 02:45 AM
String Buzz
Riase the action till you can get a 3 (yes 1/2) step bend without it choking. I'd return it to the shop to have the 22nd taken care of now, don't wait.
Rich is offline
Cort EVL-K4 Setup High e string buzz problem,,,, need help !!! klaus12 All Other Guitars (including Prestige) 1 09-30-2012 04:16 PM
Guitar Setup - string action? bhuether All Other Guitars (including Prestige) 51 08-22-2012 05:55 PM
First Fret Buzz High E and B string setup help please. possible shim? massatari Tech: Setup, Repairs and Mods 1 04-17-2012 10:10 PM
UV777BK string action problems mordil Ibanez JEM, UV, JS & Other Signature Models 6 02-24-2008 04:17 AM
JS1000 String Buzz Question jippy Tech: Setup, Repairs and Mods 5 10-05-2004 06:21 AM
HTML code is On
