Stupid Question - define 1 piece neck - Jemsite
post #1 of 14 (permalink) Old 02-02-2010, 02:57 PM Thread Starter
I see on the specs page that the Jem7 has a 1 piece neck.
My Jem7 looks to have 2 pieces of maple. The main neck is one piece, then I can see a curved shape seam (big U shape) that starts around the second fret and make a turn at about the 3/4" below the screws that hold the locking nut).
It's clearly 2 pieces of wood...the grain is different.
Serial Number on the back of the headstock starts with F01.
funbnme is offline
post #2 of 14 (permalink) Old 02-02-2010, 03:01 PM
Re: Stupid Question - define 1 piece neck
Headstock does not count, neck itself is one piece... right?
nafigator is offline
post #3 of 14 (permalink) Old 02-02-2010, 03:14 PM
Yours is one piece alright. The new Jems and most Prestiges are 5 piece, which to my small hands are thinner.
The man himself uses a one piece neck, so he thinks they are ok.
darrenw5094 is offline
post #4 of 14 (permalink) Old 02-02-2010, 03:23 PM
It can be somewhat confusing. In the case of Ibanez, their older "1 piece" necks definitely used a separate piece for the headstock. So, in a sense, it kind of seems like they're really two piece necks. Meanwhile, the newer ones are a 5 piece design with three pieces of maple sandwiching two thin strips of walnut, wenge or bubinga. These do NOT use a separate piece for the headstock, so to me, these are almost more of a "1 piece" design than the old one, even though I know that's not technically correct.
djohns74 is offline
post #5 of 14 (permalink) Old 02-03-2010, 06:32 AM
CORRECT!
GTR-MAN is offline
post #6 of 14 (permalink) Old 02-03-2010, 08:54 AM Thread Starter
Thanks for the clarification.
Makes you wonder why some things can't be simple. 2 pieces of wood for the main structure of the neck should be called a 2 piece neck.
funbnme is offline
post #7 of 14 (permalink) Old 02-03-2010, 09:29 AM
No, the neck is one piece
The headstock doesn't count.
5p necks use additional slivers of wood for the headstock as well, without calling them 7 or 8 piece; besides that, we don't count the fretboard, do we? or the trussrod(s) ?
The u-shape glue seam is known as a scarf joint
eviltwin is offline
post #8 of 14 (permalink) Old 02-03-2010, 10:55 AM
jim777's Avatar
Agreed. The common naming convention for neck pieces is just plain stupid. A one piece neck should be one piece for neck, headstock, and fretboard like on an old Telecaster. I don't know what Ibanez would call that....
The standard Ibanez '1 piece neck' is three pieces; neck back, headstock, and fretboard.
jim777 is offline
post #9 of 14 (permalink) Old 02-03-2010, 11:07 AM
What would happen if it was snapped in half?? Would it then be a 10 piece neck or count all the parts to make 16??
post #10 of 14 (permalink) Old 02-03-2010, 01:51 PM
I think that would generally be called "kindling".
djohns74 is offline
post #11 of 14 (permalink) Old 02-03-2010, 04:11 PM
Even the old Telecaster necks (with the skunk stripe) arent true 1 pc necks either.
littlephil is offline
post #12 of 14 (permalink) Old 02-03-2010, 04:42 PM
jim777's Avatar
Because of the skunk stripe? That's there because it needs to be there really, its basically a truss rod cover. I personally don't count that as a piece, any more than I count the spacers in the Ibanez "5 piece" necks as pieces either. But the original Tele necks were 1 piece without the skunk. They just didn't last very long
jim777 is offline
post #13 of 14 (permalink) Old 02-03-2010, 07:03 PM
Good point. I'd really hate to be the luthier making a true 1pc neck. The 1 piece Ibanez necks could sort of be considered 1 piece if the headstock was cut from the same neck blank, its just been scarfed to create the headstock angle. I dont know if they are done that way, I've heard that separate pieces are used so that quite small pieces of maple can be used for necks, but the grain on my S540's neck (which is really an RG neck) looks like its from the same piece of maple. It looks almost exactly the same (although flipped over)
post #14 of 14 (permalink) Old 02-03-2010, 11:25 PM
Nothing wrong with a scarf joint and it is stronger than the rest of the neck.
Anyone here that gigged original wizards in the 80s outdoors knows how bad those one piece necks could be, you could not keep the guitar in tune during a hot day if you tried.
It all depends on the grain pattern and where on the tree the neck came from imo esp when talking wizard thin.
Your better off with the 5 piece.
Digital Jams is offline
another stupid question Homebake Tech: Setup, Repairs and Mods 7 06-06-2009 02:55 PM
This might be a stupid question, but.... Heat Miser Ibanez JEM, UV, JS & Other Signature Models 4 03-02-2006 09:25 PM
JEM7vh... 5 piece or 1 piece neck Barra R. Ibanez JEM, UV, JS & Other Signature Models 4 02-21-2006 09:03 PM
How can I define my RG is 470 or 570? Dissection All Other Guitars (including Prestige) 6 03-08-2005 02:00 PM
another stupid question... diablomozart Ibanez JEM, UV, JS & Other Signature Models 3 05-21-2004 07:53 PM
HTML code is On
