SWIRLING A GUITAR - Jemsite
post #1 of 77 (permalink) Old 07-05-2009, 06:14 AM Thread Starter
SWIRLING A GUITAR
I have had some good results from using acrylic car paints and a bucket of water but have read in many forums that I can use Humbrol enamel paint (modeling paints). Is this true?
I have tried enamel paint and all it seems to do is clump together. Will Borax help this situation or should I stay with the car paints.
Also does temperature affect the swirl process as I have noticed that water straight from the tap seems to stop the paint from swirling.
Please help.
ANT5150 is offline
post #2 of 77 (permalink) Old 07-05-2009, 07:22 AM
Brosa's Avatar
Re: SWIRLING A GUITAR
Succesfull swirlers don't give their secrets away (it's their business, just like the coca cola ingredients). The only way to find out which paint to use or which paint works the best, is trial and error.
Good luck.
Sam.
Brosa is offline
post #3 of 77 (permalink) Old 07-05-2009, 10:53 AM
... and, if you've had success with auto paints, I would stick with those and perfect them.
But, yes, I understand that Borax will prevent the clumping.
Ibateur is offline
post #4 of 77 (permalink) Old 07-05-2009, 10:57 AM
My suggestion would be to prepare some sanded, white-painted boards and experiment with a bunch of different methods until you get the result you want. I would suggest speaking to a paint distributor or a hot rod shop. I don't know anything about swirling, but my feeling would be that some type of automotive paint would work best. The reason I say that is that many automotive paints self-level very well and therefore could give you a better end result. I'd probably avoid most hobby paints because the build would be very high and they probably wouldn't level very well. These paints are intended to be used with a brush, which is why you're having a problem. Some type of thinner would be your best bet if you wanted to keep using those.
Takin' a Ride is offline
post #5 of 77 (permalink) Old 07-05-2009, 12:11 PM Thread Starter
All of your help is appreciated. Thank you.
ANT5150 is offline
post #6 of 77 (permalink) Old 07-05-2009, 01:56 PM
Check this out
http://www.youtube.com/watch?v=8XUEbXAm-hY
Scott
RNRCRAZYKNIGHT is offline
post #7 of 77 (permalink) Old 07-06-2009, 02:02 PM
Everyone asks that youtube guy "do you use this?" "do you use that?", and he never posts a single reply.
Im doing a bit of research on swirling, i got some info off project guitar (google it). The paints seem pretty easy to obtain, It helps if you have some knowledge about painting, I used to work in a car body shop many years ago, but i have allways keept my hand in so to speak.
with regards to people not wanting to tell you how its done, i just think thats a very foolish attitude to have.
some one could give me the music to Rachmaninov's 3rd piano cocerto, all the notes there in black and white, but it does not mean i would be able to play it!
jonnyboy mills is offline
post #8 of 77 (permalink) Old 07-06-2009, 03:06 PM
Anyone know where i can buy borax from?
hangingmonkey is offline
post #9 of 77 (permalink) Old 07-06-2009, 03:12 PM
for my swirls i just use SAYERLACK auto paints, a brazilian brand.
Someone able to come to Brazil-São Paulo to buy those paints? Don't think so.
"Takin' a Ride" gave you everything you should and would know about swirling.
AND that swiling video isn't a good example of how to swirl IMVHO.
He swirled a green body to some shades of gray and everybody knows you need to start from white base coat to get bright colors.
Anyway, the result on that GMC was cool, 9 out of 10.
My $0,02
WillTubarao is offline
post #10 of 77 (permalink) Old 07-06-2009, 07:32 PM
what is the clear liquid in the bucket he was pouring the paint into?
kelmaur is offline
post #11 of 77 (permalink) Old 07-06-2009, 07:42 PM
Reviews: 7
It is a rare substance and completely unnecessary for human life, I think it's called "water".
Lol
Timbaline is offline
post #12 of 77 (permalink) Old 07-06-2009, 08:06 PM
Reviews: 4
Use automotive paint, and water. There is no real need for borax, but if you insist you can get it at Walmart or the grocery store. Use a white basecoat or primer.
dccomputersa is offline
post #13 of 77 (permalink) Old 07-06-2009, 08:17 PM
Lol
I pissed my pants laughing when i saw that.
nato101010 is offline
post #14 of 77 (permalink) Old 07-06-2009, 10:59 PM
Google Marbling. Seriously.
Try drawing inks. Stuff like Speedball and whatnot.
If it doesn't float right out of the jar add a single drop of Kodak Photo-flo 200(per 5ml of ink) to the ink. Mix the hell out of it and put another drop of the (now mixed) ink on your size. If it still doesn't float then that colour won't float. Make a note and move on.
You will have to alum the surface of anything you want to marble with this method other than absorbent papers.
AxeHappy is offline
post #15 of 77 (permalink) Old 07-07-2009, 05:28 PM
Reviews: 16
I swirl as well. I don't know where the Borax came into being one of the ingredients for swirling, but I never found it to help. I've used it, if not used it, I can't tell a difference. It does give the water a slicker feel, but the paint is suspended on top of the water because it's lighter than water (because it's an oil based paint). The paint never mixes with it.
If you want to try it out on the cheap, try hobby paint. I've used Testor brand which is what you commonly find in the model car and planes section of the hobby store. I've used automotive paint too. The automotive paint gives you the biggest range of colors though.
courtney2018 is offline
Swirling a set neck guitar Jemwielder Tech: Setup, Repairs and Mods 5 10-05-2006 09:10 PM
Tut for guitar swirling here ddragon64 Ibanez JEM, UV, JS & Other Signature Models 53 02-01-2005 11:51 AM
Swirling an RG? Swirly Tech: Setup, Repairs and Mods 3 04-04-2003 12:51 PM
How much would it cost to get? - Swirling a guitar. Merlin88 Gear, Equipment, Recording & Off Topic 6 02-27-2002 07:34 PM
Swirling A Guitar ??? Any Idea Besides This - I need some he howiedaydmb Tech: Setup, Repairs and Mods 5 10-10-2001 01:54 AM
HTML code is On
