Thinking of tackling my intonation 2nite... help! - Jemsite
post #1 of 9 (permalink) Old 02-03-2005, 03:33 PM Thread Starter
problem here see, i have no intonation tool.
There is only 1 offending string however, in that of the A. Its largely out after the 15th fret, but i need it to be in tune there for the sweep arpeggios.
Is it really likely to cause me some hell without a tool?
cheers!
kev
themaidenmaniac is offline
post #2 of 9 (permalink) Old 02-03-2005, 04:24 PM
Re: Thinking of tackling my intonation 2nite... help!
it might
mrvertigo is offline
post #3 of 9 (permalink) Old 02-03-2005, 04:26 PM
Nope.....I did the job fine without one. Just takes some more time. If you visualise it right you can't go wrong.
Azrael is offline
post #4 of 9 (permalink) Old 02-03-2005, 06:46 PM
I keep hearing about this tool. What is it, how's it work?
Ferrous Lepidoptera is offline
post #5 of 9 (permalink) Old 02-03-2005, 07:53 PM
HDS
Well I know some people use a strobelight.
HDS is offline
post #6 of 9 (permalink) Old 02-03-2005, 08:44 PM
It's the EDGEADJUST tool, it's a godsend. I bought one from Rich recently. Makes intonation a lot less painful, because you don't have to loosen and retighten the string with each adjustment.
MehYam is offline
post #7 of 9 (permalink) Old 02-03-2005, 09:18 PM
There's actually two different versions of the intonation tool. One designed for the edge (and OFR type trems) and another for the low pro edge(and other low profile trems). I've got both types but seeing that I can't remember where they are I've gotten used to intonating floyds without the tool. It's actually a good investment provided that you intonate your guitar(s) often.
buddroyce is offline
post #8 of 9 (permalink) Old 02-03-2005, 10:11 PM
Ah, ok, so I should know how to use google by now...
I guess that's the tool, allowing you to adjust the saddles with the strings under tension...
post #9 of 9 (permalink) Old 02-04-2005, 04:48 AM Thread Starter
well, ive done it without it and it wasnt too bad!
adjusting the intonation is the easy part, its just slackening off the strings and tuning it all up again which is a knightmare!
thanks for the help all!
intonation tool , pro edge
Tackling Country/Bluegrass Playing guitar_legend Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 2 03-12-2010 09:21 AM
so i was thinking of.... mrjakob69 All Other Guitars (including Prestige) 31 10-06-2008 01:27 PM
Thinking of being a bad boy. gmeanie All Other Guitars (including Prestige) 13 02-13-2008 01:52 PM
Tackling guitar construction... ryan Tech: Setup, Repairs and Mods 0 05-06-2003 08:18 PM
Can I adjust the intonation without the intonation tools? - cowcowcow Tech: Setup, Repairs and Mods 3 01-15-2002 03:11 PM
HTML code is On
