Tremel-yes or Tremel-no? - Jemsite
post #1 of 27 (permalink) Old 01-08-2008, 09:27 PM Thread Starter
Question Tremel-yes or Tremel-no?
I've read so many mixed reviews regarding the tremel-no product...I've actually got my first jem (to own) coming, and I was curious what others here have to say. The one jem that I've played quite a bit had one, and the owner swears by it. However alot say a totally properly set up will negate any problems. How sensitive is it and is it worth it. Some say unless you have no plans to "raise" pitch, put the unit in. others, again, say get it set up right!!!
dahjem is offline
post #2 of 27 (permalink) Old 01-08-2008, 09:32 PM
Re: Tremel-yes or Tremel-no?
Could you tell me the "mixed" reviews that you read. I'm about to buy that product.
Kerem is offline
post #3 of 27 (permalink) Old 01-08-2008, 09:39 PM
I have one in my RG and will don't plan to have another floating trem guitar without one. It was easy to install, works exactly as it should and is simple to use. I've just got another one to put on my PRS.
They really are a great invention.
sofo is offline
post #4 of 27 (permalink) Old 01-08-2008, 09:43 PM
CosmicDebris's Avatar
Agreed
CosmicDebris is offline
post #5 of 27 (permalink) Old 01-08-2008, 09:47 PM
elcid's Avatar
Yep, get one. You'll save yourself alot of headaches
elcid is offline
post #6 of 27 (permalink) Old 01-08-2008, 09:54 PM
Theres two types of tremol-no, clamp and pin type.
Which one jemsite tremol-no users use? Are there any difference?
Erm...
I thought that edge pro has a block with 2 screws at the bottom, i didnt try to unscrew it but i think it holds springs, so which one do i need to choose?
Kerem is offline
post #7 of 27 (permalink) Old 01-09-2008, 02:07 PM
Mixed reviews? Every one I've read has been positive, and I was one of those people eagerly awaiting it's release onto the market for years!
I have one in my RG2027, and another waiting for installation whenever I perform my next annual maintenance. Yes, it can be a little tricky to install but it's certainly worth it. I intend to install one in all my trem-equipped guitars.
Awakened Sleeper is offline
post #8 of 27 (permalink) Old 01-09-2008, 02:31 PM
Reviews: 6
Can these things be lock when say you want to change the strings ? Cause i'd be sold if they could do that. I am tired of stuff bottle caps under trem.
Fender868 is offline
post #9 of 27 (permalink) Old 01-09-2008, 03:36 PM
Yes they can be locked for string changes. Also, there are no longer two types. Only the Pin type is available.
Lunatic is offline
post #10 of 27 (permalink) Old 01-09-2008, 04:32 PM
Yeah, this is the first of "mixed reviews" I've ever heard. From the sound of it, the dude reviewing just didn't know what he was doing. With the Tremol-no unlocked and the Deep-C either not installed or positioned out of the range of the trem, pull up is just as smooth as dive and you'll never know anything's in there. It's only with the Deep-C in place and locked that it's dive-only.
It's really just like an on/off switch for your trem, with an added dive-only mode. I've been using one for years now, since the prototyping phase, and honestly I'd never want to play a floating trem without one. If NOTHING else, it makes changing strings much easier since you can just lock it down and save yourself the hassle of re-balancing the trem each string.
Drew is offline
post #11 of 27 (permalink) Old 01-09-2008, 04:44 PM
taracatac's Avatar
Thumbs up Re: Tremel-yes or Tremel-no?
Here's another positive response. I love it.
taracatac is offline
post #12 of 27 (permalink) Old 01-09-2008, 05:42 PM
My one just came today, gonna install it after Kevan gets back to me regarding some installation questions.
I'll let you know what I think about it soon as!
Rekuss is offline
post #13 of 27 (permalink) Old 01-09-2008, 05:47 PM
I'm still waiting for mine to arrive from some ******* on *bay.
Gudster is offline
post #14 of 27 (permalink) Old 01-09-2008, 06:14 PM
My only problem with the unit is that I lose the thumbscrews all the time during gigs.
They should be a set thumbscrew so they can't fall out.
Otherwise it works great...
Dave
davenit is offline
post #15 of 27 (permalink) Old 01-09-2008, 06:24 PM
Dave
its very good idea you should tell this to them!
How much tremol-no costs?
65$?
Kerem is offline
equipped guitar , string tension , trem guitar
Similar Searches
what tremel-no ibanez
how to block tremel bridbe
HTML code is On
