trs tuning-trouble - Jemsite
post #1 of 5 (permalink) Old 11-09-2001, 12:39 PM Thread Starter
trs tuning-trouble
hi
I have a js100 with a lo trs II. it doesnt work very well so I wonder if any of you guys out there knows what I shall do?
loproman is offline
post #2 of 5 (permalink) Old 11-09-2001, 01:04 PM
trs tuning-trouble
loproman... resign yourself!
TRS is not that kinda thing you can rely on. There's nothing to do. That's TRS.
Just a couple suggests, anyway:
- stretch well the strings before to clamp the nut pads
- tight firmly the saddle's lock screws
- get the retainer bar as lower as you can, and if needed, take the truss-rod cover away
- clamp the nut pads firmly
more than this, there's nothing to do with a TRS.
I hope Jemsite forum' guys may help you, don't know how.
I'm sorry...
my 1million italian liras ($0.00000001)
nuno
nuno is offline
post #3 of 5 (permalink) Old 11-09-2001, 01:46 PM
trs tuning-trouble
Use the TRS as a doorstop & get an Edge/LoPro.
-Justin
sixstringphoenix is offline
post #4 of 5 (permalink) Old 11-09-2001, 04:18 PM
trs tuning-trouble
Agree!
loproman, you better find an used Edge and put it on your axe.
Don't worry about routings, nor wood works: the TRS has the same distance between bolts as the Edge's, and the cavity is bigger.
It may look a bit ugly, with all that useless cavity underneath, but you have an Edge!
Get an Edge, dude!
nuno
nuno is offline
post #5 of 5 (permalink) Old 11-09-2001, 11:20 PM
trs tuning-trouble
I also have a JS100, and you are CORRECT. *The TRS II does NOT work. *I dont know why they bother putting it on there. *I still dont know what i should do. *I can either sell the JS100 (already has DiMarzio PAF Pro and FRED) and buy something with a Lo-Pro Edge, or i could spend about $200ish getting it modded with a Lo-Pro Edge. *If i did that, i would still have the non-japanese neck. *I need to do one or the other, because i have tried just about everything to keep it in tune. *Anyone have any input on what i should do? *Thanks.
Opeth is offline
dimarzio paf , dimarzio paf pro , nut pads , paf pro , pro edge , retainer bar
korean locking nuts - loosin tuning does the hardware finish matters on tuning?? jlander Tech: Setup, Repairs and Mods 4 08-01-2006 09:43 PM
Having trouble with tuning offie All Other Guitars (including Prestige) 13 04-15-2006 09:57 AM
TRS trouble Toolhead All Other Guitars (including Prestige) 3 03-08-2003 07:11 PM
Tuning to E - Can't get back to E tuning with my UV777 Zmuzic Ibanez JEM, UV, JS & Other Signature Models 6 07-25-2001 01:12 AM
Tuning Trems and Trouble - The Triple T Turmoil Two hands31 All Other Guitars (including Prestige) 10 06-01-2001 09:15 AM
HTML code is On
