Tuning Changes Depending on Angle of the Guitar??? - Jemsite
post #1 of 15 (permalink) Old 01-17-2003, 12:34 PM Thread Starter
I swear, and I seem to be able to back it up with my tuner, that my guitar changes tuning based on the angle I hold it. I mean, I'll be in a sitting position, and the tuner says its a perfect D, and then I'll tune the guitar back down, and the guitar goes sharp. Its a JS1000 if that makes any difference. Is this normal???
Thanks
Matt
untitledblinkfan is offline
post #2 of 15 (permalink) Old 01-17-2003, 12:43 PM
Just a little thing called gravity dude. Floating bridge guitars must be tuned and especially, intonated!, absolutely perpendicular to the ground, if you're after accuracy
Rich is offline
post #3 of 15 (permalink) Old 01-17-2003, 01:04 PM Thread Starter
thanks, had a feeling it was just gravity..but i wanted to make sure. I just got done intonating the thing a few minutes ago..all by hand without that handy dandy ibanez tool..needless to say it takes a little while without one of them. I definately think i got the makings of a two neutral going on though, which is no good
matt
post #4 of 15 (permalink) Old 01-18-2003, 11:53 PM
You can intonate without the tool? What do you use?
Jeff is offline
post #5 of 15 (permalink) Old 01-18-2003, 11:54 PM
site founder 0% owner
jemsite's Avatar
you can intonate w/o the tool, it just takes alot longer... glen
jemsite is offline
post #6 of 15 (permalink) Old 01-19-2003, 02:45 AM
You have to slack the string all the way off either by detuning or a combination of detuning and blocking the bridge, it has to be slack enough to control the movement of the saddle, and if it's sharp, you have to be really slack to move the saddle away from the headstock. Move the saddle the way you need to go, aproximately how much you guess it should go, tighten, retune and check. Do it again till it's right. Multiply by 6. A pain in the ass. Look at a clear closeup of an intonated Lo Pro and set your saddles in the same spots and you will get extremely close.
Rich is offline
post #7 of 15 (permalink) Old 01-19-2003, 04:15 PM
But to move the saddle you can use your fingers?
Jeff is offline
post #8 of 15 (permalink) Old 02-11-2003, 01:08 PM
I only noticed that when i made the switch to 7- i'm sure it was happening with my 6's too, but it was probably a combination of being more pronounced from the added mass in the bridge, and sheer dumb luck.
And actually, i personally feel they should be tuned strapped on in playing position, not absolutely vertical. Grab a guitar and look at the way it hangs off you- it's not QUITE vertical, but slants in towards your body slightly. We're probably talking about differences so slight that the ear won't pick them up, but this plus a 98% stable trem might be enough to push it into audible sourness... and if it's an easy fix, better safe than sorry.
I think it's kinda cool, actually... "My guitar's bridge is so sensitive that i have to tune it strapped on, so gravity isn't a factor." Yep, i'm a dork.
-Drew
Drew is offline
post #9 of 15 (permalink) Old 02-11-2003, 02:49 PM
If it's hanging at an angle when standing, you need to drop a few pounds
Rich is offline
post #10 of 15 (permalink) Old 02-11-2003, 10:48 PM
Hey, I'm probably slimmer than you are, Rich...
Na, seriously, while i'm in no means in perfect shape, i'm 6'0" and 170, and at least passably athletic- what beer gut i have isn't enough to make that huge a difference. Not bad for 21... Rather, between body posture and the upper cutout on the back, we tend to incline the guitar slightly towards us while playing- you know, better view of the fretboard and whatnot. If it was dead parallel, even given the fact your eyes are out slightly father than your chest, we'd essentially be looking straight down onto the top of the guitar and the bass string.
Anyway, off to work on my beer gut. Er, wine gut, this time. Peace,
-Drew
Drew is offline
post #11 of 15 (permalink) Old 02-11-2003, 10:53 PM
5'8 160, I think you're right!
That's funny, mine always hung straight and I'd have to peer over to see the board, maybe I need to work on my posture?
Rich is offline
post #12 of 15 (permalink) Old 02-12-2003, 02:46 AM
Offtopicis threadus
Intonation changes dramatically with different guage strings though Rich, so a visual guide of a low pro might only be good for the same guage strings ? Wouldn't the prefered angle of trem also affect the saddle positions etc.
.... and to answer the question your about type "Did you read my comment" yes I did. I saw you mentioned "Extremely close".
Whats the latin for a thread going out of topic ? "Offtopicis threadus"
Tony
6828 is offline
post #13 of 15 (permalink) Old 02-12-2003, 02:01 PM
What? Everybody doesn't use 9-42's??
Rich is offline
post #14 of 15 (permalink) Old 02-12-2003, 04:08 PM
Yes ! and if they say they don't, they are lying. !
Tony
6828 is offline
post #15 of 15 (permalink) Old 02-12-2003, 07:29 PM
haha, you or me, man, and something tells me you're a pretty solid player, so...
I mean, we're talkign slight angle, probably sub 5 degrees, but... *shrug* who knows. between the upper bout thing there and slight pressure against the angle for the arm rest from the weight of my arm, it's just natural for the guitar to angle out a little bit...
-Drew
Drew is offline
guage strings
Problems with tuning and trem angle offie Tech: Setup, Repairs and Mods 16 06-22-2006 09:36 PM
Guitar angle and tuning -anyone else notice this? Drew Tech: Setup, Repairs and Mods 8 05-02-2002 01:39 PM
high trem angle - springs or tuning? caprile Tech: Setup, Repairs and Mods 2 04-04-2002 03:35 AM
Trem Angle - If it's wrong is it gonna hurt your guitar some Scott 74 Tech: Setup, Repairs and Mods 7 03-29-2001 09:36 PM
HTML code is On
