Universe neck joint crack - Jemsite
post #1 of 7 (permalink) Old 08-02-2010, 03:16 AM Thread Starter
Reviews: 22
Unhappy Universe neck joint crack
I bought a 1990 Universe and it has a neck joint crack.
I have yet to take the neck off to inspect the crack.
If it turns out to be in the wood and not the finish how should I fix it?
Should I take it to a shop or is this something I can fix myself?
Any advise is greatly needed and appreciated.
milkywayslipnslide is offline
post #2 of 7 (permalink) Old 08-02-2010, 05:48 AM
Re: Universe neck joint crack
i gues it is a normal crack???then it is no problem.
brianxtr is offline
post #3 of 7 (permalink) Old 08-02-2010, 12:41 PM Thread Starter
Reviews: 22
After further reading it is sounding like a very normal crack.
The crack doesn't seem to cause any issues other than I noticed it so...no worries!
The guitar plays like a dream and I really love "her".
I am very lucky to have this Universe in my family.
post #4 of 7 (permalink) Old 08-13-2010, 10:42 AM
i got an rg560 which i call my old faithfull, it to has a neck joint crack, i shouldnt worry just enjoy the old girl, she wont let you down.
robhayes is offline
post #5 of 7 (permalink) Old 08-13-2010, 11:49 AM Thread Starter
Reviews: 22
Hey thanks, she really plays like a dream....I am so lucky!
post #6 of 7 (permalink) Old 08-13-2010, 12:51 PM
Reviews: 15
If you're talking about the joint by the headstock, it's cracks are VERY easy to fix. It's a common problem with Les Pauls. I've done this on several friends' guitars.
Items:
Course sand paper
Fine Sand paper
glue (I use clear Gorilla glue)
clamps
small, thin flat head screwdriver
1- place the screwdriver into the crack to open it slightly (did I mention SLIGHTLY?). This will allow the glue to get all the way into the crack.
2- put the glue into the crack. Make sure it gets all the way down.
3- remove the screwdriver.
4- place a clamp on the joint. If your clamps do not have rubber or soft plastic ends, protect the wood by placing softer wood between the clamp and wood.
5- Let sit overnight, or even 2 nights.
6- remove the clamp.
7- scrape off any excess glue.
8- sand the area until you can't feel the crack at all.
9- If the neck is finished, go to StewMac for matching paint. Otherwise, you are done.
lespauled is offline
post #7 of 7 (permalink) Old 08-14-2010, 01:13 AM Thread Starter
Reviews: 22
Thumbs up Re: Universe neck joint crack
Thank you for your advise.
The crack is on the body where the neck bolts on (neck pocket) but it is only the paint that cracked not the wood.
Thanks again.
universe
Brand New Jem 77FP Stress Crack in neck joint Trev Ibanez JEM, UV, JS & Other Signature Models 63 04-06-2019 12:20 AM
Hairline crack on neck joint acdc51502112 All Other Guitars (including Prestige) 2 04-12-2008 04:41 PM
Seriousness of neck joint crack? Marvel627 All Other Guitars (including Prestige) 19 12-11-2006 07:25 PM
Stress crack on neck joint, or just a finish crack? m0p Tech: Setup, Repairs and Mods 6 11-09-2005 05:59 PM
Neck joint crack on older Jems - What is this "neck joint cr Matt55655 Ibanez JEM, UV, JS & Other Signature Models 1 03-06-2001 11:33 PM
HTML code is On
