Universe Neck Thickness - Which Is Right? - Jemsite
post #1 of 2 (permalink) Old 12-31-2001, 04:48 PM Thread Starter
I'm confused because I've read posts that say the new UV777BK has a "beefier" neck yet when I look at the specs, it doesn't seem true. My booklet that came with my UV777GR says thickness @ 1st fret : 20mm; thickness @ 12th fret : 21.5mm. This is also listed under "common features" in the Jemsite Jem/Universe specs section. For the UV777BK the Ibanez website says thickness @ 1st fret : 19mm; thickness @ 12th fret : 21 mm. Is it that only the 2001 UV777BK's have this thinner neck or do all of the new UV777BK's have this measurement?
CrossingStar is offline
post #2 of 2 (permalink) Old 12-31-2001, 06:43 PM
Since each UV is hand-finished (by the folks in the J-Custom shop), you're going to get variations, albeit minor, in each UV neck. *
It would be tough to find two UV necks with EXACTLY the same thickness.
Kevan is offline
custom shop
Please help to define S 570 neck thickness yearn_for_change All Other Guitars (including Prestige) 3 10-30-2012 12:27 PM
Neck Thickness whitestrat All Other Guitars (including Prestige) 4 03-07-2012 12:42 PM
DY neck thickness jemboyee Ibanez JEM, UV, JS & Other Signature Models 5 01-30-2010 01:28 PM
wizard neck vs. J custom neck thickness finstah All Other Guitars (including Prestige) 15 08-05-2007 07:18 PM
Guitar Neck Thickness robinson Gear, Equipment, Recording & Off Topic 4 09-28-2004 10:06 AM
HTML code is On
