Universe question - grounding problem? - Jemsite
post #1 of 8 (permalink) Old 09-09-2001, 03:29 PM Thread Starter
I addressed this before but got no results. *I noticed a hum when I play my UV at higher voulmes. *Never figured out what it was. *Last night when I was playing, I could hear my voice through the amp when I wasn't playing. *The guitar was picking up my voice through contact with my body and amplifying it. *When I tap in the pickguard I get a boomy noise. *I don't think this is normal. *I will have to take my guitar to a tech. *Any ideas? *Thanks.
(Edited by Leary at 3:40 pm on Sep. 9, 2001)
Leary is offline
post #2 of 8 (permalink) Old 09-09-2001, 03:42 PM
Universe question
Julio had something of the same problem with his JEM10. I don't know if he managed to solve the problem. Do you hear a load low frequency humming if you touch the pickups?
SalemB is offline
post #3 of 8 (permalink) Old 09-09-2001, 03:53 PM Thread Starter
Universe question
Its a low frequency humming for sure. *It happens when I stop playing. *Its certainly feedback of some sort. *I wonder if the wiring was botched as I had a pickup replaced that was microphonic when I bought the guitar. *Its quite annoying.
Leary is offline
post #4 of 8 (permalink) Old 09-10-2001, 12:29 AM
rvj
Universe question
Do you notice if the hum comes from all three pups? If so, try a different line cord. Also verify that the cord jack is properly grounded. It could also be the wiring. I suggest looking up the schematics for your UV and compare them with your guitar. Hope this helps and keep us posted. --rvj
rvj is offline
post #5 of 8 (permalink) Old 09-10-2001, 02:51 AM
Universe question
Hey.....
* *If you are hearing your voice in your amp when not playing, that describes the problem you had before . A grounding issue wouldn't create this.....a grounding problem creates buzz and hum...especially noticable when you quit touching the guitar depending on if it. It sounds to me like you have either a poorly wired up pickup, or else the pickup in question has become microphonic.
good luck with solving your problem!
A.J.
AJofATTICA is offline
post #6 of 8 (permalink) Old 09-10-2001, 09:40 AM
Universe question
I think AJofATTICA *is right. hearing your voice through the amp means that one (or all) of your pu's has become microphonic. Squeals and feedback are also caused by a pu being microphonic.
"Microphonics occur when any integral part of a pu loosens and becomes a source of internal magnetic induction" :glare: , or in other words, the insides of your pu are loose enough to move, and thus behaving like a microphone.
One way to overcome this problem is to encapsulate the internal structure in resin, called POTTING. When hardened, resin reduces internal shifting.
I suggest you take your baby to a tech for this potting procedure.
Cheers,
Joten
GhesQi J is offline
post #7 of 8 (permalink) Old 09-10-2001, 10:00 AM
kennydoe's Avatar
Universe question
If you can afford to be without your pickup for a few weeks, send it back to DiMarzio.
All their p'ups have 5 yr warranty on them and their support is very very good.
They will fix it or replace it for the cost of shipping. *Be sure to call them first.
~Kenny
kennydoe is offline
post #8 of 8 (permalink) Old 09-10-2001, 01:35 PM Thread Starter
Universe question
Ok I'll give that a shot. *Which schematic is the correct one for the 99 Universe? *Thanks.
Leary is offline
UV Grounding problem or Microphonic P/U'S? Jemvdy Pickups & wiring 5 07-25-2011 03:17 PM
Grounding problem. Help please. metalhead52 Pickups & wiring 7 07-19-2011 11:59 AM
Strange grounding hum problem As Hell Broke Loose Tech: Setup, Repairs and Mods 7 10-23-2009 03:41 PM
Grounding problem? John R Pickups & wiring 0 10-06-2009 07:08 PM
grounding problem(pics inside) RG270L_Guy Pickups & wiring 0 01-18-2008 02:22 PM
HTML code is On
