Urgent nut radius info for JS1000 needed... - Jemsite
post #1 of 12 (permalink) Old 02-11-2004, 01:11 PM Thread Starter
I have a thread on my nut that isnt working.
I can buy a new genuin floyd rose nut from I guy cheap.
The specs of that nut is 42 mm and a 9.5" radius or 241mm.
I was under the impresion that it was 250mm radius.
Can anyone give me the right specs of the nut for the JS1000.
THX I'm in deep... and in Belgium (No nuts from the importer on stock)
:P
deloosem is offline
post #2 of 12 (permalink) Old 02-11-2004, 01:15 PM
If it doesn't have the truss channel hupm radius doesn't matter.
Rich is offline
post #3 of 12 (permalink) Old 02-11-2004, 01:33 PM Thread Starter
I'm affraid I don't follow you. Please elaborate a bit. Maybe its the language barrier.
If I want the exact as the original I got from Ibanez (I mean the form) is that one the good one.
I have 2 links:
I got the radius info here: http://www.geocities.com/louferri/js1000spec.html
And this is the Nut I want to buy: http://www.gitaarmarkt.nl/index.php?...tails&id=19725
Sorry to bother you with it.
deloosem is offline
post #4 of 12 (permalink) Old 02-11-2004, 01:40 PM
Look at the hump in the base of the JS nut.
Rich is offline
post #5 of 12 (permalink) Old 02-11-2004, 01:44 PM Thread Starter
Ok Saw the Hump.
So I can order It ? The info on the other site is false ?
SO I order it right ?
I feel so silly...sorry
Just tell me Yes order it Deloosem. And I will do so...
deloosem is offline
post #6 of 12 (permalink) Old 02-11-2004, 01:47 PM
ASK them if it has the hump, if it doesn't it's useless.
Rich is offline
post #7 of 12 (permalink) Old 02-11-2004, 03:31 PM Thread Starter
Rich,
Its a no no. It doesn't have the "hump".
I know you have them. And my Brother In Law is living in the Boston Area. I will let him pay you. I'll mail you personaly to get the details.
Can you tell me what the part nr is for the nut of a JS1000BTB.
THX for the help man. You are the man...
Marc
deloosem is offline
post #8 of 12 (permalink) Old 02-11-2004, 03:47 PM
2TL1JS42B
Rich is offline
post #9 of 12 (permalink) Old 02-11-2004, 05:52 PM Thread Starter
2TL1JS42B
I will contact you today or tommorow.
Any other parts you suggest me buying from you for my JS's. I have a JS1000 and a JS2000(pre 2003 model) ?
I mean things like posts, whatever.
deloosem is offline
post #10 of 12 (permalink) Old 02-11-2004, 05:59 PM
Dunno, having a problem with anything?
Rich is offline
post #11 of 12 (permalink) Old 02-11-2004, 06:08 PM Thread Starter
Yes with the bad (No) support here in Belgium. For the nut thing I had to wait 2 months and what did they get me 3 pads with 3 screws not what I asked.
I am always looking for better tuning stability. New post an option ?
I do have a problem with the Trem arm moving. It seems there is an awfull lot of space between the top of the tube where the arm inserts and the arm its self.
I read all the articels here on tightening the thing but its thight and it still moves. I'm used to it now but any thoughts on it would be cool.
Anyway if you think of things like: Ok he will need this and this...make suggestions...
deloosem is offline
post #12 of 12 (permalink) Old 02-11-2004, 08:40 PM
You strip the base or something?
If the guitars are post mid year 01' [about 25000 on the serial] they should have the new studs, I'd check before ordering something you don't need
http://www.ibanezrules.com/tech/setup/loose_holder.htm
Rich is offline
floyd rose , trem arm
URGENT HELP NEEDED!!! marko-slash Tech: Setup, Repairs and Mods 4 06-18-2008 06:27 PM
Urgent! Help Needed! Please! Now! Help Me! carlos grijalva Off-topic / Miscellaneous 42 07-16-2006 08:48 PM
Any JS900 users? Info needed - URGENT PLEASE!! strat110 Ibanez JEM, UV, JS & Other Signature Models 6 05-18-2005 06:49 PM
Info needed on RG2620 QM -URGENT- Jem7RB MK All Other Guitars (including Prestige) 1 12-07-2004 02:12 PM
Ibanez Radius info needed SonicDefiance All Other Guitars (including Prestige) 15 07-05-2003 10:31 AM
HTML code is On
