UV70p's Edge-Zero II-7 bridge - Jemsite
post #1 of 29 (permalink) Old 10-02-2014, 03:17 AM Thread Starter
Hi just coming from here http://www.jemsite.com/forums/f16/ib...fr-133058.html ,
Pulled the trigger for the UV70p Universe!
I read some negative online reviews about Edge-Zero II-7 bridge. How would you rate it? Will it be reliable and durable? I am no stranger to fixing, setting up floyds. I have set up and even repaired two of floyds of mine. Where are the weak points of this bridge? Maybe the knife edges ?
panix is offline
post #2 of 29 (permalink) Old 10-02-2014, 03:22 AM
Re: UV70p's Edge-Zero II-7 bridge
The major problem with all the EZ's is there is no steel saddle lockdown plate and you can strip the treads in the baseplate setting intonation. That's bad, don't do it.
Rich is offline
post #3 of 29 (permalink) Old 10-02-2014, 03:37 AM Thread Starter
Thanx Rich,
You mean I will have to follow the one-finger rule when fastening those saddle bolts? Be more cautious than this? Or simply never touch them?
If this happens, Is there any remedy to this? except buying a new trem? Would a solution with e.g. Helicoil work?
Anyways, i haven't paid yet. Should I do it? Should I buy this?
panix is offline
post #4 of 29 (permalink) Old 10-02-2014, 08:53 AM
Contributor
sebastian's Avatar
Just don't over-tighten the bolts and you won't have a problem.
sebastian is offline
post #5 of 29 (permalink) Old 10-02-2014, 09:14 AM Thread Starter
Thanx bro, that means, just turn them with my right little finger, (cause the left one is stronger i guess )
panix is offline
post #6 of 29 (permalink) Old 10-02-2014, 10:42 AM
I've stripped 3 now and I don't overtighten anything.
Yes, helicoil is the answer if you can get somebody to do it, but if you strip one hole, don't touch any of the rest, they'll probably go too. I don't believe the metallurgy is equal with all the batches.
Rich is offline
post #7 of 29 (permalink) Old 10-02-2014, 10:49 AM Thread Starter
Thanx Rich,
Don't you think the helicoil repair (or a variation) would be doable if someone does some practice on a spare plate?
so for 880 EUR new, would you think this is a good deal to go for?
And if i buy it, should i "stress test" it in the first month (while in the 30 days return period) and return it if broken?
Or should i just be careful during the 3 years guarantee and then never touch any saddle intonation bolt again?
in short should i buy it or not?
panix is offline
post #8 of 29 (permalink) Old 10-02-2014, 11:51 AM
I have no idea what pricing is like in Europe.
Rich is offline
post #9 of 29 (permalink) Old 10-02-2014, 02:43 PM Thread Starter
Alright guys, so if it breaks after the guarantee, is there any Gotoh/Floyd Rose direct fit replacement for this bridge? Or am i supposed to buy the whole thing for some 300 USD? (and hope it doesn't collapse again)
panix is offline
post #10 of 29 (permalink) Old 10-02-2014, 02:58 PM Thread Starter
Hey, looking at the bottom of the plate :
wouldn't be possible to just glue a steel plate with a matching template from below - or just an individual nut, and then use the same metric bolts, just a little longer to bite the extra steel/or nut beneath?
panix is offline
post #11 of 29 (permalink) Old 10-02-2014, 05:35 PM
A great idea! Would be quite a bit of work. You would also have to make sure you have enough clearance from the bottom of the baseplate to the body.
In any case, as Rich pointed out with the issues with the bridge, I got rid of all of my J Custom and Prestige guitars that I had with the EZ Bridge. I liked it a lot at first but then I started having issues with one of them after a few years. Then the next guitar went south on me. That was enough for me to move back to Edge Pro guitars. No issues since.
PBGas is offline
post #12 of 29 (permalink) Old 10-02-2014, 06:00 PM
RGTFanatic's Avatar
That is a great idea. You could use the unused intonation bores to screw a new steel plate to the bottom.
You would have to recess the area of the body between the anchors to accommodate the depth of the new plate and any fasteners used. This would be a great fix for a stripped plate, but I wouldn't do it until one of them WAS stripped.
Conversely, If you knew a machinist you could get a steel plate recessed into the base- then the original intonation screws would be fine.
RGTFanatic is offline
post #13 of 29 (permalink) Old 10-02-2014, 08:26 PM
It's gotta be 2mm thick so that's a lot of height to overcome with neck angle, but it's doable. You can use an edge plate on a 6, but not a 7 unless all the screws were in the front holes, and the B saddle on a 7 will always be in the rear hole. Since a machine shop would have to make the plate to begin with, helicoil is the logical answer. Helicoil all the holes and you'll never have to worry about it.
Rich is offline
post #14 of 29 (permalink) Old 10-03-2014, 07:07 AM Thread Starter
So, I suppose a better Ibanez MIJ tremolo or an after market tremolo e.g. OFR 7-string or FR 1000-7 string is out of the question?
Does it require serious mods/routing?
panix is offline
post #15 of 29 (permalink) Old 10-03-2014, 11:17 AM Thread Starter
Another solution maybe ? how about using rivets? drilling out the hole and attaching from below smth like a rivet :
with a tang strong enough to keep the saddle down.
panix is offline
bridge , edge-zero ii-7 , uv70p
UV70p panix Ibanez JEM, UV, JS & Other Signature Models 0 10-02-2014 02:36 AM
Just bought UV70P! mrchims Ibanez JEM, UV, JS & Other Signature Models 7 08-25-2014 07:56 PM
Ibanez UV70p green dot universe milleniumking Classified Ads: Ibanez JEM/UV Guitars 0 06-08-2014 05:19 AM
WTT: my Gold Schaller FR bridge for your Black Lo Pro Edge or Edge bridge supergirl20_06 Classified Ads: Guitars and Gear 2 08-05-2011 05:57 AM
HTML code is On
