UV777 Neck to be installed on a RG7620 body..possible? - Jemsite
post #1 of 4 (permalink) Old 04-20-2003, 01:04 AM Thread Starter
Hi guys,
I've got a quick question...is it possible for me to install the UV777 universe neck onto a normal RG7620 body? I've got a beat up UV neck which I would like to fix onto the body. Is it a quick and easy one-off installment or do I have to do some major adjustments to the neck joints etc?
Would appreciate all your inputs
Thanks in advance...
triaxis is offline
post #2 of 4 (permalink) Old 04-20-2003, 01:11 AM
As long as it's a 777 neck [AANJ] it should mate right up.
Rich is online
post #3 of 4 (permalink) Old 04-20-2003, 09:22 PM Thread Starter
Yeah..its a AANJ..mm...so it should fit just right...just 'screw it in' eh heh
Thanks a lot Rich!
triaxis is offline
post #4 of 4 (permalink) Old 04-21-2003, 10:01 AM
It may require a little sanding to fit just right. I have a similar issue with a LA Custom shop neck and a 7620 body...the neck pocket is just ever so slightly smaller than it should be for this neck. Jeremy is taking care of everything for me,in addition to a bunch of other stuff.
Word of caution, if it is too tight...do not force it too much or you will risk crack the pocket on the lower end.
Gresh is offline
custom shop , neck joint , neck joints
JS2000 neck in a JS1000 body - factory installed bigrocco19 Ibanez JEM, UV, JS & Other Signature Models 1 06-01-2012 09:36 AM
FS: Christopher Woods body, RG7620 neck, LoPro Edge, Evolution mechanyx Classified Ads: Guitars and Gear 1 06-22-2010 08:22 PM
FS: RG7620 neck and body, EMG 707 + 81-7, DiMarzio New 7's DSS3 Classified Ads: Guitars and Gear 4 03-05-2010 12:08 PM
WTT: Blue RG7620 body for a Grey Nickel 7620 body kevin7 Classified Ads: Guitars and Gear 0 11-17-2005 10:43 AM
RG7620 Neck on UV style body ? megadeth Tech: Setup, Repairs and Mods 2 03-06-2005 09:02 AM
HTML code is On
