UV777 string selection , will this mess up my trem? - Jemsite
post #1 of 7 (permalink) Old 08-12-2004, 04:45 PM Thread Starter
I have a UV 777 and when i got it it has really light strings on it possibly 9'-52.
I play metal and want a beefier string but dont want to mess up my trem or neck. Is it possible to buy packs with a top of 13 or 12 to a 64 or 70 low string?
also will this mess up either my neck and or trem?
also who sells a custom set of strings similar to that all i can find are 10 -56 ?
thanks in advance
UV777guy is offline
post #2 of 7 (permalink) Old 08-12-2004, 10:58 PM
Your best bet will probably be to go to juststrings.com and order individual strings. That way, you'll get everything exactly the way you want it.
The_Grindfiend is offline
post #3 of 7 (permalink) Old 08-13-2004, 03:57 AM
I think I once put a set on with 62 or 64 at the bottom and these almost max'd out the springs. If you go higher you may need shorter/thicker springs.
edit: On UV777BK
Sunrise is offline
post #4 of 7 (permalink) Old 08-13-2004, 12:04 PM
I use 10s with a 65 on my universe and it playes great
gunther is offline
post #5 of 7 (permalink) Old 08-13-2004, 01:45 PM
10-60 on a 7620- I need four springs to keep the tension up on this, but I see no reason why you couldn't go to five springs and use a 74... Although, it's worth noting that i believe an .80 is the largest string youc an get through the stock tuning peg- you'd either need to (CAREFULLY) drill it out more, or replace it with a bass peg.
-D
Drew is offline
post #6 of 7 (permalink) Old 08-16-2004, 09:34 AM
I have a .74 on my 2027, tuned to low A, and the string is too thick to get in the peg, but you can cut off the ball end as much as the thinner part of the string goes through the peg.
I have 3 springs, and the guitar is fully intonated. No problem.
rest of the strings is 10-52, regular D- tuning D-G-C-F-A-D.
Tony
tony777 is offline
post #7 of 7 (permalink) Old 08-16-2004, 10:21 AM
Most Universes are set up for 9s right out of the factory. If you wanna use heavier strings, by all means go ahead, but you need to adjust the spring tension to compensate for the extra string tension; you also need to tighten the trus rod so the neck can with stand the pull of heavy strings. I really don't recommend using anything heavier than 10's on guitars with neck this thin but it's your guitar and it's your music. Just make you sure make the proper adjustment, namely the trus rod and spring. If those are properly adjusted, heavier strings shouldn't do any damage.
-Bo
bobojem is offline
string tension
best trem selection for Mexican strat is? evolvedmb All Other Guitars (including Prestige) 9 09-14-2009 01:00 AM
Mess Around 7 string? alecmm61 All Other Guitars (including Prestige) 3 09-20-2008 01:10 PM
Trem selection question Homeless All Other Guitars (including Prestige) 1 02-21-2007 11:08 PM
Help just got my UV777 back and the trem is screwed up ? UV777guy Ibanez JEM, UV, JS & Other Signature Models 11 08-25-2004 07:20 PM
UV777 Individual string heights 1 1 Dragon 2 2 2 Ibanez JEM, UV, JS & Other Signature Models 3 01-04-2001 07:36 PM
HTML code is On
