UV777BK pickup height issue - Jemsite
post #1 of 14 (permalink) Old 04-04-2016, 02:18 PM Thread Starter
Hi Everyone,
My UV is a little under the weather...
See the neck pickup? I can't raise it on the right side. Seems to be stripped enough so after a few turns of the height adjustment screw the spring pushes it back to the bottom. So what do I do now?
Leviathus is offline
post #2 of 14 (permalink) Old 04-04-2016, 04:56 PM
Re: UV777BK pickup height issue
You have to remove the string and the pickguard and fix it !
Agent540 is offline
post #3 of 14 (permalink) Old 04-05-2016, 05:29 PM Thread Starter
Well, how insightful!
anyone else?
post #4 of 14 (permalink) Old 04-05-2016, 05:45 PM
Looks like someone used the wrong height adjustment screws because they wanted them to be silver.
Takin' a Ride is offline
post #5 of 14 (permalink) Old 04-05-2016, 06:27 PM Thread Starter
They're stock, just faded.
post #6 of 14 (permalink) Old 04-05-2016, 11:58 PM
Screw hole can be rethreaded. Take out pickup and find lokal workshop that can do that.
It is few second job.
peromucho7 is offline
post #7 of 14 (permalink) Old 04-06-2016, 02:35 AM
It's really not as easy as just re tapping the threads on the pickup, if the thread is stripped then you'll more than likely have to go the next size up which means getting larger screws and redrilling the pickguard holes to suit. You'd also have to do all the the pickup screws for it to match. You may be lucky and it's only the screw that's stripped but I wouldn't think so but you never know till you take the thing to pieces. Also getting larger screws might not be as easy as you think with the correct heads on them.
morris"squid finger"daley is offline
post #8 of 14 (permalink) Old 04-06-2016, 12:29 PM
One of two things could have happened.
1) simplest - it's possible that the pickup has just been backed out SO far that the screw disengaged - can you pull the screw free with little pressure? If so, then this is a simple matter of popping out the trem, unscrewing the pickguard, flipping it over, and re-seating the screw into the pickup and tightening it back up.
2) harder - the pickup may be stripped out. Couple tings you could do, either repleave it with a screw one size larger that will bite in the pickup, or possibly just lining the center of the thing with a semi-soft epoxy or even just a bit of hard wax (sealing wax might work well, actually), and then threading the screw through while it was still a bit soft, to kind of re-create the threading inside the pickup.
Of course, if you're not 100% happy with the sound of the pickup, this might be a good opportunity to just bite the bullet and try something else.
How did this happen? Did something push down on the pickup hard? Were you lowering it and it just fell loose?
Drew is offline
post #9 of 14 (permalink) Old 04-06-2016, 02:08 PM Thread Starter
I've had the guard off and i'm very certain the pickup tab is stripped. Some dudes on sevenstring.org said i could very nimbly attatch a nut to the tab with superglue or somethin.
Perhaps going a screw size up would be easier, i dont really care if theres one odd screw on the pickguard. Guess I'm still weighing my options.
I'd rather not have to buy a new pickup and wire it in. I aint got no beef with the Blazes nah mean?! I'm lookin for the simplest quickest fix.
Thanks for all of your input guys!
post #10 of 14 (permalink) Old 04-06-2016, 02:42 PM
A little dab of superglue will fix most anything, including stripped threads on a pickup.
Rich is offline
post #11 of 14 (permalink) Old 04-06-2016, 03:04 PM Thread Starter
So you mean just putting a little on the tab threads and then letting it dry to close it up a little, then the screw will basically re-thread itself?
post #12 of 14 (permalink) Old 04-06-2016, 03:07 PM
If you have accelerator there is no wait, but, yes. Easiest fix there is.
Rich is offline
post #13 of 14 (permalink) Old 04-06-2016, 03:14 PM Thread Starter
Its so crazy it just might work!!!
Thanks Rich
post #14 of 14 (permalink) Old 04-06-2016, 03:16 PM
Done it many times.
Rich is offline
height , ibanez , pickup , problem , universe
UV70p Edge-Zero II-7 bridge saddle height issue panix Tech: Setup, Repairs and Mods 4 10-16-2014 09:35 AM
Pickup height IBZguitars_rkoko Pickups & wiring 4 02-16-2010 09:04 PM
Pickup height Dee All Other Guitars (including Prestige) 13 08-14-2006 01:17 AM
Pickup height gumby604 Pickups & wiring 4 08-06-2003 03:23 PM
Pickup Height? Globbits Tech: Setup, Repairs and Mods 6 11-27-2002 05:44 PM
HTML code is On
