UV777BK string action problems - Jemsite
post #1 of 7 (permalink) Old 02-23-2008, 05:45 PM Thread Starter
Hi,
on my UV777BK the string action is damn high around the 12th fret. It tried to lower the floyd but it doesnīt help much. So I also tried to adjust the neck but it also doesnīt help much around the 12th fret / higher frets.
Does someone know what Iīm doing wrong?
Iīm not the first owner of the Universe so I thought maybe the first owner highered the locking at the headstock. So I took a look and found to thin metal-like pieces as seen of on the photo. Does it come with the factory setting? I was just wondering.
But I believe that it also wonīt change the action on the higher strings. I hope you guys have some suggestion for me, because that action is way to high for such an high-end guitar.
thx
mordil is offline
post #2 of 7 (permalink) Old 02-23-2008, 06:11 PM
Reviews: 7
Re: UV777BK string action problems
Yeah, they come shimmed. Besides the nut has nothing to do with frets that high.
Are you sure you didn't back off the locking stud screws (down the center of the trem posts)? You might not be getting the trem as low as you could if you forgot to do that.
A picture of the bridge would help too.
If that's not the case. How much relief does the neck have? Fret the first and last frets on the low B and check how much space is between the frets and the strings. Let me know what kind of gap your getting at it's biggest.
brothersnowgone is offline
post #3 of 7 (permalink) Old 02-23-2008, 07:05 PM Thread Starter
hi, thx for the fast response.
I "unscrewed" the locking stud screws to lower the floyd to the max. But even then the action is high.
When I ret the 1st and 24th fret the height at the 7th fret is really low. Thatīs ok, the problem is more ah the higher string.
When i donīt fret any strings the hieght on the high E string is about 1 mm at the 12 fret. It isnīt quite nice to shred there
mordil is offline
post #4 of 7 (permalink) Old 02-23-2008, 08:53 PM
Reviews: 7
What is it at the 24th?
post #5 of 7 (permalink) Old 02-23-2008, 10:20 PM Thread Starter
about 1.5-1.9 mm
mordil is offline
post #6 of 7 (permalink) Old 02-23-2008, 11:35 PM
Reviews: 7
That's actually a decent action. Not high by most people's standards. If it's hard to play fast up there just work on it more. I like to think I play somewhat fast and I'd say my action is a tad higher than yours and I play 6's for the most part.
post #7 of 7 (permalink) Old 02-24-2008, 04:17 AM
Dont forget if you lower the action too much the strings fret out when you pull up on the trem. I know not every one likes to pull up on the trem but i love it, I can play fast with about 1mm of action. You dont have to have really low action to play fast, just practice more. Its a compromise between the two, really low action means no pulling up, and if you love Steve Vai's style then its a must.
morris"squid finger"daley is offline
higher strings , locking stud , steve vai
String Vibration Problem CosmicDebris Tech: Setup, Repairs and Mods 3 01-01-2008 09:36 PM
Unusual String Breakage and Tuning stability problems junebughunter Ibanez JEM, UV, JS & Other Signature Models 9 11-08-2005 12:50 PM
Where to measure string action? eg Tech: Setup, Repairs and Mods 13 09-26-2002 02:40 PM
string problems woodros Tech: Setup, Repairs and Mods 4 08-17-2002 02:21 AM
String Buzz - problems with low-action setup on JS1000 tadd251 Ibanez JEM, UV, JS & Other Signature Models 4 03-19-2001 02:45 AM
HTML code is On
