UV777BK wont stay in tune - Jemsite
post #1 of 6 (permalink) Old 06-25-2002, 09:35 PM Thread Starter
Ive found that my uv777bk's trem will not return to the correct pitch under trem workouts it come back sharp after i pull up and flat after i push down this leaves all of the strings mildly out of tune but it is noticeable has anyone else had this problem. also i have found that compared to all of my fellow jemsiters rants about the stability of the lo pro edge7 mine dosent work worth a ****. if any of you guys could help me out with this it would be much apreciated
Dead Roman is offline
post #2 of 6 (permalink) Old 06-25-2002, 10:02 PM
site founder 0% owner
jemsite's Avatar
the jemsite TECH SETUP area has alot of info on troubleshooting a locking trem... glen
jemsite is offline
post #3 of 6 (permalink) Old 06-25-2002, 11:20 PM
What year is the UV?
Rich is offline
post #4 of 6 (permalink) Old 06-25-2002, 11:28 PM
First answer Rich, if he has some info it will be well worth it.
Second, tighten the nut srews on the back of the neck. Tighten the neck screws. Make sure the little screw down in the posts is tight. For anything else the Tech section as said before will have this and much more in detail.
BrianH is offline
post #5 of 6 (permalink) Old 06-26-2002, 01:43 AM Thread Starter
this is an brand new 02 uv bought online from musiciansfriend and ive gone through most of the stuff related to this in the setup area but a double check couldnt hurt eh?
post #6 of 6 (permalink) Old 06-26-2002, 10:04 AM
I have found that all three of my lo pro 7 trems have a different sweet spot. My UV likes to be tilted ever so slightly toward the rear of the guitar, just barely past parallel. The 2027 is dead parallel but the treble side needs to be up a touch. The 7620 I just got is also dead parallel but the bass side jacked up a touch. If I waver from these setting, it won't stay in tune.
Also, since your guitar is brand new, it will take some time for the springs to find "home" and the guitar will not stay in perfect tune until they do. In the meantime, double check your set up and then really abuse the trem, full on slack string dive bombs, bar flutters....really stretch those strings and do that every day for a while. Works like a charm and your guitar will feel less stiff.
Gresh is offline
neck screws , pro edge
Trem arm wont stay in place. miniche All Other Guitars (including Prestige) 7 03-24-2013 03:16 PM
Wont Stay In Tune with NEW Gotoh Ge1996 ozjem Tech: Setup, Repairs and Mods 68 04-18-2011 02:39 AM
strings wont stay tuned??? rhinojohn2112 Tech: Setup, Repairs and Mods 2 02-21-2007 07:36 PM
UV777PBK wont stay in tune? morris"squid finger"daley Ibanez JEM, UV, JS & Other Signature Models 12 11-01-2006 05:55 PM
Wont stay in tune dohdoh Tech: Setup, Repairs and Mods 5 11-02-2005 09:02 PM
HTML code is On
